Hi Everyone, quick question. Im trying to use eval() inside a python loop and it doesn’t return the correct result when called inside a function. Does anyone have any ideas?
import maya.mel as mel
#correct output
for i in range(0,3):
m = mel.eval('$i = `python i`;')
print ("Correct: py=" + str(i) + " mel=" + str(m))
#incorrect output
def fn():
print ("Incorrect: py=" + str(i) + " mel=" + str(m))
fn()
for context Im trying to loop through all the takes inside an FBX file, then perform some other actions. Unfortunately the function causes mel.eval() to fail.
def fn():
importDir = "C:\my.fbx"
mel.eval('FBXRead -f `python "importDir"`')
takes = mel.eval('FBXGetTakeCount')
for i in range(1,takes):
print mel.eval('FBXGetTakeName `python "i"`')
fn()
def fn():
cmds.FBXRead('-f', importDir)
takes = cmds.FBXGetTakeCount()
for i in xrange(1, takes + 1):
print(cmds.FBXGetTakeName(i))
fn()
There is also pymel’s mel syntax which I tend to prefer, because you can use keywords arguments instead of string flags.
import pymel.core as pm
def fn():
pm.mel.FBXRead(f=importDir)
takes = pm.mel.FBXGetTakeCount()
print(pm.mel.FBXGetTakeName(i))
fn()
Also, you have a bit of a bug in your range(1, takes), you need to add one to the take count, as range(1, 1) returns an empty list.
And you should probably be careful with your importDir = “C:\my.fbx”, you’re not properly escaping your backslash.
