Perhaps the biggest tip of all:
Do all your work in a real text editor, then paste it into the custom node
Otherwise you’ll end up murdering people.
There aren’t enough likes on this forum to truly express how much I agree with this.
Since in a custom node you can’t exactly (easily) input other custom nodes, I found defining your functions in a Struct is something I found pretty useful
So something like:
struct ExampleStruct
float ExampleFunc(float input)
return input;
ExampleStruct f;
return f.ExampleFunc(0);
I found this is the next best thing to just adding though a .USF, and haven’t really seen this documented anywhere
I’ve got a better example here that shows an actual use case, this can all hypothetically just be pasted into the custom node:
_https://github.com/BhMbOb/Code/blob/master/Shaders/shd_volumeRaymarch_default.hlsl_
