Is it possible to highlight custom menu items with those green brackets?
Yes, you can get QMenu items and dump them for inspection. Did some to custom color menu items in the node editor fiddling around with it. The dump will however be a huge trove of āQMenuItems##ā and so on so to find the correct one might be a pain using the same method I used. If you add the menu items yourself with Qt you should however know how to access your items.
Damn.
I was hoping to do that without QT as I donāt have any experience with that.
Anyway, Thank you!
Found the python tab I had the code in when I looked into this, maybe it could help.
import pymel.core as pm
def recursive_children(qt_object, level=0):
print ' ' * level + type(qt_object).__name__
children = qt_object.children()
for child in children:
recursive_children(child, level)
level += 1
def widget_parser(widget):
""" Recursive listing of a widgets structure, """
children = widget.children()
print type(child).__name__
# Get the node editor as a Qt object,
node_editor = pm.getPanel(scriptType='nodeEditorPanel')[0]
node_editor_qt = node_editor.asQtObject()
widget_parser(node_editor_qt)
recursive_children(node_editor_qt)
Probably the easiest way to do this is just use the version
flag on cmds.menuItem
, if the version value == the current running version of Maya, it will highlight. Otherwise it wonāt.
If youāre using mel, and maya LT, you need to use ltVersion
instead.
wow. appreciate the code. iāll look into this. it is due to get some basic qt knowledge at least.
Well, thatās embarrasing. Iāve tried using this flag before. Must have done something wrong it seems.
Thank you!!
@cur10us you should mark Bobās answer as the āsolutionā so future lurkers know thereās a definitive answerā¦
sorry for late response. i canāt seem to find how to mark an answer as the solution
OK, I did it. Looks like there was a plugin setting that changed a version ago, hiding the option.
