Trouble with drag-and-drop pyqt widgets in Maya
Hey guys,
I’m exploring a qt ui for a Maya tool that I’d like the ability to drag and drop icons (qlabels with pixmaps). I’ve looked over the examples in the pyqt folder. Below I listed the snippet of code I’m currently using (taken mostly from the examples), the label is draggable but I can get the “invalid circle symbol” when it follows the cursor. The .ui file I built in Designer has a groupBox with a qlabel on top that will act as a background image for the user. Currently when you release the button while dragging it just puts it back at the creation position. I assume the issue has something to do with stacking widgets? But when I remove the background image qlabel, and just try it on a plain groupbox - the issue is the same.
Thanks for the help!
Jason
class DragLabel( QtGui.QLabel ):
    def __init__( self, widget, item, pixmap, listWidget, parent ):
        super( DragLabel, self).__init__( parent )
        self.parent = parent
        self.setPixmap( QtGui.QPixmap( pixmap ) )
        self.itemName = item.text()
        self.item = item
        self.listWidget = listWidget
        self.widget = widget
        self.setAcceptDrops(True)
        #self.setContextMenuPolicy( QtCore.Qt.CustomContextMenu )
        #self.customContextMenuRequested.connect( self.popup )
    def mousePressEvent( self, event ):
        @synopsis: Function for mouse Press event
        @para:
            event - qt mouse event
        # If Right mouse button, display popup menu
        if event.button() == QtCore.Qt.RightButton:
            self.popup( event.pos() )
        else:
            pixmap = self.pixmap()
            itemData = QtCore.QByteArray()
            dataStream = QtCore.QDataStream( itemData, QtCore.QIODevice.WriteOnly )
            dataStream << pixmap << QtCore.QPoint( event.pos() - self.rect().topLeft() )
            mimeData = QtCore.QMimeData()
            mimeData.setData( 'application/x-characterBtn', itemData )
            drag = QtGui.QDrag( self )
            drag.setMimeData( mimeData )
            drag.setPixmap( pixmap )
            drag.setHotSpot( event.pos() - self.rect().topLeft() )
            self.hide()
            if drag.exec_( QtCore.Qt.MoveAction | QtCore.Qt.CopyAction, QtCore.Qt.CopyAction ) == QtCore.Qt.MoveAction:
                self.close()
            else:
                self.show()
class DragWidget( QtGui.QWidget ):
    def __init__( self, itemName, pixmap, listWidget, parent=None, x=25, y=25 ):
        super(DragWidget, self ).__init__( parent )
        self.label = DragLabel( self, itemName, pixmap, listWidget, parent )
        self.label.move( x, y )
        self.label.show()
    def dragEnterEvent( self, event ):
        if event.mimeData().hasFormat( 'application/x-characterBtn' ):
            if event.source() == self:
                event.setDropAction( QtCore.Qt.MoveAction )
                event.accept()
                self.mouseReleaseEvent = self.dropEvent
            else:
                event.acceptProposedAction()
        else:
            event.ignore()
    def dropEvent( self, event ):
            itemData = event.mime.data( 'application/x-characterBtn' )
            dataStream = QtCore.QDataStream( itemData, QtCore.QIODevice.ReadOnly )
            pixmap = QtGui.QPixmap()
            offset = QtCore.QPoint()
            dataStream >> pixmap >> offset
            newLabel = DragLabel( pixmap, self.parent )
            newLabel.move( event.pos() - offset )
            newLabel.show()
                event.accept()
            else:
        else:
            event.ignore()
