Time Slider Issue
Hey, I’m trying to create an animation GUI for animators but my biggest problem is getting the key ticks to show in my own created time slider.
The timePort command has nothing to show key ticks, but the timeControl command does, but attaching it is pretty confusing. I think that is all that I have to do but I could be wrong.
I’m going to attach the time slider that Maya create’s to show what I have been following. If any one knows of a work around that would be awesome. Thanks, I’ll keep posting my progress.
If you’re generating your own timeslider then you have very little control over what you can use in it. Maya only supports the default timeSlider, all you get by generating your own is the timeSlider ui itself. Or at least that was the case last time I looked
[QUOTE=Mark-J;4908]If you’re generating your own timeslider then you have very little control over what you can use in it. Maya only supports the default timeSlider, all you get by generating your own is the timeSlider ui itself. Or at least that was the case last time I looked[/QUOTE]
Ya I know this one but I wanted to know if there was a way I could make the keyticks like Maya or take out Maya’s timeslider and replace it with my own.
