Talking about Light Transport
EDIT: Feel free to reply with new terms and even correct my definitions! Original post with wiki links [here].
Whether you’re a technical artist in games or film, when trying to create realistic scenes and characters, the more you know about how light works and interacts with surfaces in the world, and the more reference of this you have, the better you can explain why you think an image looks ‘off’.
You are an technical artist. You need to be able to communicate with technical people using terminology they understand. We often act as bridges between artists and programmers, it is very important for us to be able to communicate with both appropriately.
Light transport is basically the big nerd word for how light gets from one place to another, and scattering is usually how surfaces interact with light.
You can see something in a rendered image and know it looks ‘wrong’, but it’s important to understand why it looks wrong, and be able to accurately explain to the programming team how it can be improved upon. To do this you should be able to:
present examples of photographic reference
communicate with general terms that others can understand
General Terminology
The following terms come from optics, photography and art, you should not only understand these, but use them when explaining why something does not look ‘right’. I will give both the technical term and my shortest approximation:
Specular Reflection - sharp reflection of light from a surface that somewhat retains an image (eg. glossy)
Diffuse Reflection - uneven reflection of light from a surface that does not retain the image (eg. matte)
Diffuse Interreflection - light reflected off other diffuse objects
Diffraction - what happens to a wave when it hits an obstacle, this could be an ocean wave hitting a jetty, or a light wave hitting a grate.
Depth od Field - the area in an image that is in focus
Bokeh - the blurry background in a photo that is not in focus
Chromatic Abberation - the colored fringes around an object or light refracted through an object, it’s because certain wavelengths of light get bent ‘out-of-sync’, i usually think of it as an old projector or monitor that is misaligned; that’s what this effect looks like.
Caustics - light rays shined through a refractive object onto another surface
Angle of Incidence - this is actually the angle something is off from ’straight on’, but we mainly use this when talking about shaders or things that are view-dependent. If you were to draw a line from your eyes to a surface, the angle between this and it’s ‘normal’ is the ‘angle of incidence’. Car paint whose color changes as you walk around it is a good example: it changes based on the angle you see it. Just remember, your head doesn’t have to move, the object can move, changing the angle between your sightline and the surface.
Refractive Index (Refraction) - how light’s direction changes when moving through an object. the refractive index of water is 1.3, glass has a higher refractive index at 1.4 to 1.6
Reflection - the changing of direction of light, usually casting light onto something, like the camera or our eyes
Glossiness - the ability of a surface to reflect specular light, the smaller amount of specular light reflected usually makes something look ‘glossier’
Ray - think of a ray as a single beam of light; a single particle. This particle moves in a ‘ray’, when we talk about ‘ray tracing’ we mean tracing the path of a ray from a light source through a scene.
Fresnel - pronounced ‘fre-nel’, it is the amount of view dependent reflectance on a surface. a great example is rim lighting, but fresnel effects are used to fake a fuzzy look, x-ray effects, light reflected off the ocean, etc.
Aerial Perspective - this is how things get lighter as they recede into the distance, the more air, or ‘atmosphere’ between you and the object (mountain, building, etc) the lighter it is visually. I grew up in Florida, we don’t have much of this effect at all due to elevation and clear skies.
High Dynamic Range Imaging (HDR) - this just means you are dealing with more light data than a normal image. An HDR image has a larger range of light information stored in it. With today’s prosumer DSLR’s it is possible to capture 14bit images that theoretically contain ‘13-14 stops’ of linear data. A digital example could be the sky in the game Crysis, it was a dynamic HDR skydome, this meant that the game engine was computing more light than could be displayed on the monitor. In these situations, this data is tonemapped to create visually interesting lighting situations.
Tone Mapping - this is how you can ‘map’ one set of colors onto another, in games it generally means ‘mapping’ high dynamic range data into a limited dynamic range, like a tv set or monitor. This can be done by ‘blooming’ areas that are overbright and other various techniques.
Bloom - ‘bloom’ is the gradiant fringe you see around really brightly lit areas in an image, like a window to a bright sky seen from inside a dark room.
Albedo - the extent to which a surface diffusely reflects light from the sun.
Afterimage Effect - this belongs to a groups of effects I call ‘accumulation-buffer effects’. the after-image effect visually ‘burns-in’ the brightest parts of a previous image, simulating the effect our eyes have when adjusting to bright light.
Deferred Rendering - this is a type of rendering where you render parts of the image to framebuffer storage instead of rendering directly to the pixel-output. Deferred rendering generally allows you ot use many more light sources in real-time rendering. One problem deferred rendering has is that it cannot properly deal with transparent items.
Scanline Rendering - Scanline rendering is a very old technique where you render one line of pixels after another. Pixar’s Renderman is a scanline renderer, but also the NintendoDS uses scanline rendering.
Skylight (or Diffuse Sky Radiation) - this is the fancy term for light that comes not from the sun, but is reflected from the sky. It is what makes sunlight on earth inherently blue, or orange.
Scattering (including Sub-Surface Scattering) - this just means how particles are ’scattered’ or deviate from an original path. In sub-surface-scattering, light enters an object, and bounces around inside (sub-surface). This leads to things like the orange/red color of your ear when there it a light behind it.
Participating Media - the way a group of particles can effect light transport through their volume, not only reflect or refract light, but scatter it. Things like glass, water, fog and smoke are all participating media.
Ambient Occlusion - this is a shading effect where occluded areas are shaded, much like access maps of the old days, cracks and areas where light would have a hard time ‘getting into’ are shaded.
Screen Space Ambient Occlusion - a rendering technique that fakes ambient occlusion with some z-buffer trickery. By taking the distances between objects in a scene, the algorithm generates approximated occlusion data in real time. (first used on Crysis!)
Global Illumination - a way of rendering where you measure light bounces, as the light bounces around a scene, this generates indirect lighting. An example of this would be how a red ball next to a white wall will cast red light onto the wall.
Z-Buffer - is where 3d depth information is stored in a 2d image. A 16bit z-buffer has 65536 levels of depth, while an 8 bit has 256. Items on the same level cause flickering or ‘z-fighting’.
Z-Fighting - this occurs when polygons have similar z-buffer values, it is a term you should know when dealing with virtual cameras, not real ones. You can see this flickering when you create 2 co-planer planes on top of each other in a 3d app. To eleminate z-fighting you can use 24 or 32bit zbuffers.
Frustrum - everything in the camera’s field of view; generally the entire volume that the camera can see.
Environment Reflection - the way of faking a reflection by applying an image to a surface, this can be a spherical map, cube map, etc. Some environmental reflections (cubemaps) can be generated at rutime as you move an object around. (most notably in racing games)
Cubic Environment Mapping - a way of generating an environmental reflection map with six sides that are mapped onto a cube, recreating the reflection of the environment around an object.
SkyBox - creating a ’sky’ in a virtual scene by enclosing the entire scene in a large box with images on 5 sides.
Here are some example sentences:
Artist: This place here where the light shines on the surface is too small, it makes my object look too wet.
Technical Artist: The surface is too glossy, as a result, the area of specular reflection where you see the light is very small.
Artist: Like in the photos we took, things in the distance should be lighter, in the engine can we make things lighter as they get farther away?
Technical Artist: As things recede into the distance, aerial perspective causes them to become lighter, to acheive this we should increase the environment fog slightly.
Taking Photographic Reference
I feel every technical artist should own a proper Digital Single Lens Reflex camera (DSLR), no matter what quality or how old. This will force you to understand and work with many of the terms above. The artist in you will want to take good pictures, and this is much more than good composition, you are essentially recording light. You will need to learn a lot to be able to properly meter and record light in different situations. Because it’s digital, you will be able to iterate and learn fast, recognizing cause and effect relationships the same way we do with the realtime feedback of scripting languages in 3d apps.
