http://area.autodesk.com/blogs/chris/the_maxsharp_project_python_and_c_from_3ds_max_2011
:D: Merry Christmas :D:
Recently we posted on the Autodesk Developer Network an experimental library we have been developing in conjunction with EPHERE called MaxSharp. MaxSharp provides a simplified wrapper around the 3ds Max 2011 API that can be used from both Python and C#. If you are an ADN Sparks member you can download it from this url. Be aware that because this is a research project you can’t redistribute the DLLs, but you can still use them for your own internal use.
