sublist
September 9, 2011, 6:06am
1
Hi there.
I’m not a max user at all but i have to prepare some stuff in max.
Is there an easy way to search an replace numbers or letters in Object/Material Names.
I would like to eliminate whiteSpace and special Character etc…
Do i need a script or is there something built-in?
Thxs
alelink
September 9, 2011, 6:40am
2
Hi!
never used that script but seems to do the job you need:
http://www.scriptspot.com/3ds-max/scripts/rp-renametools
but give a look at this page too, maybe you’ll find more scripts suitable for your needs:
http://www.scriptspot.com/3ds-max/scripts/tags/rename
sublist
September 9, 2011, 7:20am
3
Tried that script. Seems that it only supports objects. No Materials etc…
here’s an old one that will replace all ‘invalid’ chars (IE: Charachters that wouldn’t work in a filename) with a _ in materials and object names
toolTip="remove invalid chars (obj.name obj.mat.name)"
buttonText="remove invalid chars (obj.name obj.mat.name)"
--start macro
dno_regexreplace = (dotNetObject "System.Text.RegularExpressions.Regex" "[^\w]").Replace
ReplaceChar = "_"
fn replaceIt mat =
if (mat != undefined) do
mat.name = dno_regexreplace mat.name ReplaceChar
)--end function
sel = selection as array
for n = 1 to sel.count do
sel[n].name = dno_regexreplace sel[n].name ReplaceChar
if classof sel[n].material == Multimaterial then
for i in 1 to sel[n].material.numsubs do
replaceIt sel[n].material.materiallist[i]
else
Not the prettiest code, but its always worked well.
