does anyone know how to create an ep curve with python?
Using the “curve” command creates a cv curve. But I need my curve to run through the center of every joint, as I want to use it for a dynamic bone chain later.
I tried to use the “fitBspline” command after creating my cv curve which seemed to work fine, it rebuilds my cv curve with a point in the center of every joint. But when I then use the maya “makeCurveDynamic” command, the output Curve doenst match the input curve. It looks quite similiar, but the points are not longer in the center of the joints.
