Reading text from a QLineEdit with Python
In my ongoing quest to work with Qt to build UIs, I have a hard time figuring out how to read text from a QLineEdit. I built my interface with QtDesigner, added a QLineEdit and gave it the name “txtMyText”.
What’s the correct way to query the text from this QLineEdit. I assumed I could do something like
cmds.textField("txtMyText", query = True, text = True)
but that gives me an error:
# RuntimeError: Object 'txtMyText' not found.
Which, when you think about it, makes sense since a QLineEdit is not the same as a textField.
But how then do you find the QLineEdit “txtMyText” from a script?
Any help is appreciated!
Ack, why do I always find a solution after I post here… ? :slight_smile:
Anyhoo, the solution I’m using now is the following:
My imports and global ui variable
from maya import OpenMayaUI as omui
from PySide.QtCore import *
from PySide.QtGui import *
from PySide.QtUiTools import *
from shiboken import wrapInstance
from stringBuilder import *
import os
import pymel.core as pm
ui = "thisIsNothingForNow"
To create the UI I use this function
def CreateUI():
	mayaMainWindowPtr = omui.MQtUtil.mainWindow()
	mayaMainWindow = wrapInstance(long(mayaMainWindowPtr), QWidget)
	loader = QUiLoader()
	file = QFile("D:/Dropbox/QtFiles/checkupScriptUI.ui")
	file.open(QFile.ReadOnly)
	global ui
	ui = loader.load(file, parentWidget = mayaMainWindow)
	file.close()
Then in the function I want to use the entered text I do the following:
def TEST():
	global ui
	words = ui.txtMyText.text()
	print words
I would recommend reading the Qt Documentation when you have specific questions about a particular widget. You can often find examples in the description covering basic usage.
The docs are in C++, so it takes a little effort to translate to python.
http://qt-project.org/doc/qt-4.8/qlineedit.html
This PyQt documentation is also a good source for answers. Does it pretty well for me. It is not as complete as the c++ one but close enough.
http://pyqt.sourceforge.net/Docs/PyQt4/modules.html
