from PySide import QtCore
from PySide import QtGui
from PySide.QtGui import QApplication, QMainWindow, QMessageBox
import main.pyside_dynamic as pdy
class MyMainWindow(QMainWindow):
QMainWindow.__init__(self, parent)
pdy.loadUi('E:/test.ui', self)
if __name__ == "__main__":
MyMainWindow()
I would appreciate any help to get this working.
Thanks,
Vikram.[/QUOTE]
I’ve pretty much given up on getting loadui to work and have gone back to compiling to code with the uic crap. If PySide had better support, I would say that we should request PyQt like support for ui loading. Loading a pre-compiled .py is faster than dynamically loading a .ui anyway, so I might have gone this route regardless.
I think nathan horne wrote/ported a function for pyside that was similar in function to how pyqt does it. We used to do the compile to py, but iterating is a pain in the ass. With UI files, its way faster and less overhead.
[ul]
[li]DO NOT USE cmds.loadUi!!![/li]> [LIST]
[li]seriously, don’t… forget it exists, now.[/li]> [li]Who ever wrote it needs to be punched in the mouth.[/li]> [/ul]
[li]Use uic/pysideuic (PySide has an alternate setup here), it’s awesome![/li]> [li]Note: pysideuic is lacking a loadUiType function, I have a workaround that I will try to mention in the example code. (Edit: here’s some PySide loadUiType code)[/li]> [li]The uic.loadUiType function is the one that should be used for loading in a PyQt UI from a designer file.[/li]> [li]Depending on how your resources are set up you may wish to alter the UI file before passing it to the loadUiType command. (See resources section below)[/li]> [/LIST]
[QUOTE=TheMaxx;22657]I think nathan horne wrote/ported a function for pyside that was similar in function to how pyqt does it. We used to do the compile to py, but iterating is a pain in the ass. With UI files, its way faster and less overhead.
What problems did you experience? Every so often i’ll hit a bug and have to dig into the exported py string to figure out what went wrong, but for the most parts it’s very smooth.
[QUOTE=TheMaxx;22662]What problems did you experience? Every so often i’ll hit a bug and have to dig into the exported py string to figure out what went wrong, but for the most parts it’s very smooth.[/QUOTE]
We use that one, but we added a bunch of things to the system path otherwise it couldn’t find some resource files or our subclasses. Once we added those, it’s been pretty solid
So I did replace the uiLoad with the one Nathan Horne mentioned, but still cannot get the ui window. His explanation is primarily for PyQt, but asks to use the pysideuic module for Pyside and the second thing I have changed is to use the shiboken module to get the Maya window. Here’s my code of Nathan’s PyQt example:
import pysideuic
import xml.etree.ElementTree as xml
from cStringIO import StringIO
from PySide import QtGui, QtCore
from shiboken import wrapInstance
import maya.OpenMayaUI as apiUI
def getMayaWindow():
Get the main Maya window as a QtGui.QMainWindow instance
@return: QtGui.QMainWindow instance of the top level Maya windows
ptr = apiUI.MQtUtil.mainWindow()
if ptr is not None:
return wrapInstance(long(ptr),QtGui.QWidget)
def loadUiType(uiFile):
Pyside lacks the "loadUiType" command, so we have to convert the ui file to py code in-memory first
and then execute it in a special frame to retrieve the form_class.
parsed = xml.parse(uiFile)
widget_class = parsed.find('widget').get('class')
form_class = parsed.find('class').text
with open(uiFile, 'r') as f:
o = StringIO()
frame = {}
pysideuic.compileUi(f, o, indent=0)
pyc = compile(o.getvalue(), '<string>', 'exec')
exec pyc in frame
#Fetch the base_class and form class based on their type in the xml from designer
form_class = frame['Ui_%s'%form_class]
base_class = eval('QtGui.%s'%widget_class)
return form_class, base_class
#If you put the .ui file for this example elsewhere, just change this path.
listExample_form, listExample_base = loadUiType('E:/example1.ui')
class ListExample(listExample_form, listExample_base):
def __init__(self, parent=getMayaWindow()):
super(ListExample, self).__init__(parent)
self.setupUi(self)
#The names "addItemBtn" and "removeItemBtn"
#come from the "objectName" attribute in Qt Designer
#the attributes to access them are automatically created
#for us when we call setupUi()
#Designer ensures that the names are unique for us.
self.addItemBtn.clicked.connect(self.addItem)
self.removeItemBtn.clicked.connect(self.removeItem)
def addItem(self):
Add a new item to the end of the listWidget
item = QtGui.QListWidgetItem(self.listWidget)
item.setText('Item #%s!'%self.listWidget.count())
def removeItem(self):
Remove the last item from the listWidget
count = self.listWidget.count()
if count:
self.listWidget.takeItem(count-1)
Here’s the .ui file (currently pointing to E:/example1.ui) :
I made a boilerplate which works either with PyQt or PySide (you set a variable to choose which one you want to use) in Maya, Nuke or as completely standalone. It should get you started:
I’m doing a blog post with some details on customizing it and I can post back the link when it’s published.
I picked up this code from a previous poster and tried to make it work.
And actually it works quiet well except when you click outside the gnerated window it will lose it’s focus and you can’t cancel it anymore or do anything.
Any idea how to wrap it to not lose focus?
pyside only of course since it’s supported by maya now, also I can’t have pyQt in our studio, we need to go out of the box due to whatever politics things.
that’s for the python code
import pysideuic
from pprint import pprint as pp
if ptr is not None:
o = StringIO()
frame = {}
exec pyc in frame
listExample_form, listExample_base = loadUiType('C://PATH_TO_YOUR_UI_FILE.ui')
self.setupUi(self)
le = ListExample()
le.show()
and for qt designer ui file, just try with some empty design or something random test.
I’'d have to play with this code to see what it would take to make this support modal dialogs, but here’s a link since I’m not going to have time to play anytime soon.
im assuming its a dialog and its modal and it doens’t look like its parenting to maya correctly. your getMayaWindow() function could still return None thus not parenting to maya and just having a floating window. If that’s not the case, i’d have to see your ui file
[QUOTE=TheMaxx;28001]im assuming its a dialog and its modal and it doens’t look like its parenting to maya correctly. your getMayaWindow() function could still return None thus not parenting to maya and just having a floating window. If that’s not the case, i’d have to see your ui file[/QUOTE]
No idea what that modal or not modal does. I’m quiet new to using PySide, still learning.
this is an example ui file created with designer, just an empty window.
It happens to any kind of template or window you create in the designer, so the code that’s wrong is already within the python code so I guess it’s a wrapping problem.
edit:
solved it, the window was not closed proberly.
I found some help here on tech-artists regarding win-event errors and found this to help me. Now it’s not losing focus anymore
global win
try:
win.close()
except:
pass
win = ListExample()
win.setAttribute (QtCore.Qt.WA_DeleteOnClose)
win.show()
