QDataWidgetMapper and multiple ModelIndex
I have one question : i have created a tool based of this tutorial : https://youtu.be/Gil-dg3ajbA?t=556
On this tutorial, you can change for example an attribute on the light B :
But what i want is to do is to select the light A and B, and change the attribute, and the value will be changed for A and B. How can i do this ?
How QDataWidgetMapper will work with multiple selection ?
The problem is that my QDataWidgetMapper can have just one “setCurrentModelIndex”. But because i have multiple things selected, what is the solution please ?
Thank you,
Damien
you should be able to query which items are selected in your tree view, and set their values directly after retrieving the new value.
Removed post.
