Hi all, I am trying to get the state of the ‘viewTransform’ button (as depicted here) whenever viewport2.0 is used.
I was not able to find much information online as I am trying to toggle this button/ state across all model panels (the main viewport and tear off panels if any)
This command allows querying and editing the color management global data in a scene. It also allows for setting the view transform and rendering space which automatically configures the color processing in the enabled views.
This is the button that I am trying to query and set the state for:
I also did tried out the command as you have mentioned, using cmEnabed but it seems to be querying for the global prefs instead of the button state within the viewport/ modelPanels or in other tear off panels
Ok - you’ll need to get the model panel and then query the colour managment state - I’m looping through all model panels and returning their state:
for pane in cmds.getPanel( type='modelPanel' ):
print cmds.modelEditor(pane, q=True, cmEnabled=True)
You may have to filter by visible pane potentially - something like this:
for pane in cmds.getPanel( visiblePanels=True):
if cmds.getPanel(typeOf=pane) == "modelPanel":
