I was wondering if anyone had any experience (good or bad) utilising dictConfig to create and manage log objects for toolsets across multiple users on a network?
Say we create a json file like so;
"version": 1,
"formatters":
"basic":
"format": "%(asctime)s - %(name)s - %(levelname)s - %(message)s"
"verbose":
"format": "%(asctime)s - %(pathname)-17s line:%(lineno)-4d - %(levelname)-8s - %(message)s"
"handlers":
"console":
"class": "logging.StreamHandler",
"level": "INFO",
"formatter": "basic",
"stream": "ext://sys.stdout"
"file":
"class": "logging.handlers.RotatingFileHandler",
"level": "DEBUG",
"formatter": "verbose",
"filename": "~/testdmp/log.log",
"maxBytes": 1000000,
"backupCount": 3
"loggers":
"ldtools":
"level": "INFO",
"handlers": ["console"],
"propagate": "no"
"users":
"Lee.Dunham":
"level": "DEBUG",
"handlers": ["console", "file"],
"loggers":
"ldtools":
"level": "DEBUG",
We then check for user specific logging data (After converting the dict data from Unicode to Str), update the dict and strip out invalid data prior to loading it.
from .constants import * # Relative file containing constants
import copy
import json
import logging
# -- Setup Logger
log = logging.getLogger(LOGGER_NAME)
log.setLevel(logging.INFO)
def configure_dict_config(file_data):
Configure and validate logging dictConfig data.
This allows us to configure the dict config data, allowing user specific
logging events.
:param file_data: Dict config to configure and validate.
:type: dict
:return: dict
# -- Essentially we want to get all of the data, then check if the user is
# -- specified to use particulars (log debug to filepath). If so then we
# -- alter the data to reflect the settings for the user.
# -- Validate data type
if not isinstance(file_data, dict):
raise TypeError('File data is not a dictionary: %s ' % file_data)
return
# -- Copy given data to configure for a return value
config_data = copy.deepcopy(file_data)
# -- Check for user specific logging events
if 'users' in config_data:
# -- Pull the unsupported data out
users_data = config_data.pop('users')
# -- Get data specifically for user
user_data = users_data.get(USER)
if user_data:
# -- Configure the data from the user's specifications
# -- We can expect; levels, handlers, loggers
loggers = config_data.get('loggers')
if loggers:
update_data = {}
# -- Here we specify the extra data we'll want to use
# -- Levels
if 'level' in user_data:
update_data['level'] = user_data['level']
# -- Handlers
if 'handlers' in user_data:
update_data['handlers'] = user_data['handlers']
# -- If any data is specified, edit all loggers to use
for key in loggers:
config_data['loggers'][key].update(update_data)
return config_data
def load_config():
Load configured logging config data.
:return: None
# if os.path.isfile(LOGGING_CONFIG):
# -- Get config data from file
with open(LOGGING_CONFIG, 'r') as f:
file_data = json.loads(f.read())
config_dict = configure_dict_config(file_data)
if config_dict:
logging.dictConfig(config_dict)
As far as I can tell, this works as expected (as long as the tools grab the correct logger name ala .constants).
Being able to manage the logging handlers and formatters on a user level allows me to hook to beta testers, redirect logging outputs and introduce new handlers down the line with minimal fuss (from what I can tell).
This seems to be what I’m looking for (minimal setup for a large amount of flexibility and scalability) so I’m wondering if anyone uses something like this and has tips to avoid pitfalls or am I looking in the wrong direction?
Thanks,
Lee
