There was a discussion on the slack about timing functions to get some perf data and I remebered I had this beauty laying around.
import functools
from timeit import default_timer as timer
def deco_timer(self, func):
DECORATOR: Use to get an automatic start/stop message around the function
prints metadata of function.__class__.__qualname__ Started/Finished
so we can track times
@yourLib.deco_timer
def some_func():
pass
Args:
func (function): function to wrap
Returns:
function: wrapped function
@functools.wraps(func)
def wrapper(*args, **kwargs):
"""Wrapper function for tracking time taken for a given function"""
if hasattr(func, "__call__"):
name = func.__module__
else:
name = func.__class__
start_time = timer()
start_metadata = f"{name}.{func.__qualname__}"
print(start_metadata)
# run wrapped func
out_val = func(*args, **kwargs)
# log the time taken just for the sake of it
time_taken = "{:4f}".format(timer() - start_time)
finish_metadata = f"{name}.{func.__qualname__} : Time Taken:{time_taken}"
print(finish_metadata)
return out_val
return wrapper
I usually put this in a utils.py somewhere on PATH and it makes it easy to put around the code base if/when you want to check things as you can then just do
import utils
@utils.deco_timer
def foo():
Hope it helps
