Hey guys,
I am stuck with trying to recreate the lights structure inside maya.
My dictionary returns wildly random mixed lights.
I tried implementing the Ordered dict function but not sure how to use it on the code.
https://docs.python.org/2/library/collections.html#collections.OrderedDict
here my code:
allObjects['LGT'] = {"type": "transform", "parent": None}
for i in range (0, x):
transform, shape = self.getTransformAndShape(allTransforms[i])
lgt = transform.split('|')[-1:][0]
if self.isLight(shape):
parents = mc.listRelatives(transform, parent=True)
parent = None
if parents:
parent = parents[0]
if parent == "lgt":
parent = None
allObjects[lgt] = {"type": "light", "parent": parent}
elif self.isLightSource(shape):
parent = None
if parents:
parent = parents[0]
if parent == "lgt":
parent = None
allObjects[lgt] = {"type": "meshLight", "parent": parent}
elif self.isEnvironmentLight(shape):
parent = None
if parents:
parent = parents[0]
if parent == "lgt":
parent = None
allObjects[lgt] = {"type": "environmentLight", "parent": parent}
elif self.hasLightsChildren(transform):
if transform == "lgt":
pass
parent = None
if parents:
parent = parents[0]
if parent == "lgt":
parent = None
allObjects[lgt] = {"type": "transform", "parent": parent}
return allObjects
CODE BREAKDOWN
the output is:
parent = None
if parents:
parent = parents[0]
if parent == "lgt":
parent = None
allObjects returns: {u’TEST_KEY’: {‘type’: ‘light’, ‘parent’: u’TEST_lights’}, u’ALL_KEY16’: {‘type’: ‘light’, ‘parent’: u’ALL_lights’}, u’ALL_KEY15’: {‘type’: ‘light’, ‘parent’: u’ALL_lights’}, u’ALL_KEY14’: {‘type’: ‘light’, ‘parent’: u’ALL_lights’}, u’ALL_KEY11’: {‘type’: ‘light’, ‘parent’: u’ALL_lights’}, u’ALL_KEY10’: {‘type’: ‘light’, ‘parent’: u’ALL_lights’}, u’TEST_KEY1’: {‘type’: ‘light’, ‘parent’: u’TEST_lights’}, u’TEST_KEY2’: {‘type’: ‘light’, ‘parent’: u’TEST_lights’}, u’ALL_KEY_switchtest’: {‘type’: ‘light’, ‘parent’: u’ALL_lights’}, u’ALL_KEY’: {‘type’: ‘light’, ‘parent’: u’ALL_lights’}, u’LOC_KEY’: {‘type’: ‘light’, ‘parent’: u’LOC_lights’}, u’TEST_lights’: {‘type’: ‘transform’, ‘parent’: u’TEST’}, u’ALL’: {‘type’: ‘transform’, ‘parent’: u’LGT’}, u’ALL_KEY8’: {‘type’: ‘light’, ‘parent’: u’ALL_lights’}, u’ALL_KEY3’: {‘type’: ‘light’, ‘parent’: u’ALL_lights’}, u’ALL_KEY2’: {‘type’: ‘light’, ‘parent’: u’ALL_lights’}, u’ALL_KEY1’: {‘type’: ‘light’, ‘parent’: u’ALL_lights’}, u’ALL_KEY7’: {‘type’: ‘light’, ‘parent’: u’ALL_lights’}, u’ALL_KEY6’: {‘type’: ‘light’, ‘parent’: u’ALL_lights’}, u’ALL_KEY5’: {‘type’: ‘light’, ‘parent’: u’ALL_lights’}, u’ALL_KEY4’: {‘type’: ‘light’, ‘parent’: u’ALL_lights’}, u’ALL_lights’: {‘type’: ‘transform’, ‘parent’: u’ALL’}, u’TEST’: {‘type’: ‘transform’, ‘parent’: u’LGT’}, ‘LGT’: {‘type’: ‘transform’, ‘parent’: None}}
parent returns: ALL_lights
parent returns: TEST_lights
parent returns: LOC_lights
lgt returns: ALL_KEY
lgt returns: ALL_KEY1
lgt returns: ALL_KEY2
lgt returns: ALL_KEY3
lgt returns: ALL_KEY4
lgt returns: ALL_KEY5
lgt returns: ALL_KEY6
lgt returns: ALL_KEY_switchtest
lgt returns: ALL_KEY7
lgt returns: ALL_KEY8
lgt returns: ALL_KEY14
lgt returns: ALL_KEY15
lgt returns: ALL_KEY16
lgt returns: ALL_KEY10
lgt returns: ALL_KEY11
lgt returns: TEST_KEY
lgt returns: TEST_KEY1
lgt returns: TEST_KEY2
lgt returns: LOC_KEY
lgt returns: LOC_KEY1
- the sort order of lgt is still correct here, and that’s how it needs to appear in the groups when parented here further down.
pass
parent = None
if parents:
parent = parents[0]
if parent == "lgt":
parent = None
print 'allObjects returns: %s' %allObjects
#print 'parent returns: %s' %parent
allObjects returns: {u’TEST_KEY’: {‘type’: ‘light’, ‘parent’: u’TEST_lights’}, u’LOC_lights’: {‘type’: ‘transform’, ‘parent’: u’LOC’}, u’ALL_KEY16’: {‘type’: ‘light’, ‘parent’: u’ALL_lights’}, u’ALL_KEY15’: {‘type’: ‘light’, ‘parent’: u’ALL_lights’}, u’ALL_KEY14’: {‘type’: ‘light’, ‘parent’: u’ALL_lights’}, u’ALL_KEY11’: {‘type’: ‘light’, ‘parent’: u’ALL_lights’}, u’ALL_KEY10’: {‘type’: ‘light’, ‘parent’: u’ALL_lights’}, u’TEST_KEY1’: {‘type’: ‘light’, ‘parent’: u’TEST_lights’}, u’TEST_KEY2’: {‘type’: ‘light’, ‘parent’: u’TEST_lights’}, u’ALL_KEY_switchtest’: {‘type’: ‘light’, ‘parent’: u’ALL_lights’}, u’ALL_KEY’: {‘type’: ‘light’, ‘parent’: u’ALL_lights’}, u’LOC_KEY1’: {‘type’: ‘light’, ‘parent’: u’LOC_lights’}, u’LOC_KEY’: {‘type’: ‘light’, ‘parent’: u’LOC_lights’}, u’TEST_lights’: {‘type’: ‘transform’, ‘parent’: u’TEST’}, u’ALL’: {‘type’: ‘transform’, ‘parent’: u’LGT’}, u’ALL_KEY8’: {‘type’: ‘light’, ‘parent’: u’ALL_lights’}, u’ALL_KEY3’: {‘type’: ‘light’, ‘parent’: u’ALL_lights’}, u’ALL_KEY2’: {‘type’: ‘light’, ‘parent’: u’ALL_lights’}, u’ALL_KEY1’: {‘type’: ‘light’, ‘parent’: u’ALL_lights’}, u’ALL_KEY7’: {‘type’: ‘light’, ‘parent’: u’ALL_lights’}, u’ALL_KEY6’: {‘type’: ‘light’, ‘parent’: u’ALL_lights’}, u’ALL_KEY5’: {‘type’: ‘light’, ‘parent’: u’ALL_lights’}, u’ALL_KEY4’: {‘type’: ‘light’, ‘parent’: u’ALL_lights’}, u’ALL_lights’: {‘type’: ‘transform’, ‘parent’: u’ALL’}, u’TEST’: {‘type’: ‘transform’, ‘parent’: u’LGT’}, ‘LGT’: {‘type’: ‘transform’, ‘parent’: None}}
parent returns: ALL
parent returns: LGT
parent returns: LGT
parent returns: LOC
parent returns: LGT
lgt returns: ALL_lights
lgt returns: ALL
lgt returns: TEST_lights
lgt returns: TEST
lgt returns: LOC_lights
lgt returns: LOC
for the purpose of simplicity I only attached the returns of the transforms and groups.
now the final output is:
allObjects output is: {u’TEST_KEY’: {‘type’: ‘light’, ‘parent’: u’TEST_lights’}, u’LOC’: {‘type’: ‘transform’, ‘parent’: u’LGT’}, u’LOC_lights’: {‘type’: ‘transform’, ‘parent’: u’LOC’}, u’ALL_KEY16’: {‘type’: ‘light’, ‘parent’: u’ALL_lights’}, u’ALL_KEY15’: {‘type’: ‘light’, ‘parent’: u’ALL_lights’}, u’ALL_KEY14’: {‘type’: ‘light’, ‘parent’: u’ALL_lights’}, u’ALL_KEY11’: {‘type’: ‘light’, ‘parent’: u’ALL_lights’}, u’ALL_KEY10’: {‘type’: ‘light’, ‘parent’: u’ALL_lights’}, u’TEST_KEY1’: {‘type’: ‘light’, ‘parent’: u’TEST_lights’}, u’TEST_KEY2’: {‘type’: ‘light’, ‘parent’: u’TEST_lights’}, u’ALL_KEY_switchtest’: {‘type’: ‘light’, ‘parent’: u’ALL_lights’}, u’ALL_KEY’: {‘type’: ‘light’, ‘parent’: u’ALL_lights’}, u’LOC_KEY1’: {‘type’: ‘light’, ‘parent’: u’LOC_lights’}, u’LOC_KEY’: {‘type’: ‘light’, ‘parent’: u’LOC_lights’}, u’TEST_lights’: {‘type’: ‘transform’, ‘parent’: u’TEST’}, u’ALL’: {‘type’: ‘transform’, ‘parent’: u’LGT’}, u’ALL_KEY8’: {‘type’: ‘light’, ‘parent’: u’ALL_lights’}, u’ALL_KEY3’: {‘type’: ‘light’, ‘parent’: u’ALL_lights’}, u’ALL_KEY2’: {‘type’: ‘light’, ‘parent’: u’ALL_lights’}, u’ALL_KEY1’: {‘type’: ‘light’, ‘parent’: u’ALL_lights’}, u’ALL_KEY7’: {‘type’: ‘light’, ‘parent’: u’ALL_lights’}, u’ALL_KEY6’: {‘type’: ‘light’, ‘parent’: u’ALL_lights’}, u’ALL_KEY5’: {‘type’: ‘light’, ‘parent’: u’ALL_lights’}, u’ALL_KEY4’: {‘type’: ‘light’, ‘parent’: u’ALL_lights’}, u’ALL_lights’: {‘type’: ‘transform’, ‘parent’: u’ALL’}, u’TEST’: {‘type’: ‘transform’, ‘parent’: u’LGT’}, ‘LGT’: {‘type’: ‘transform’, ‘parent’: None}}
as we see, the sort order is complete random.
How can I append to the dictionary while maintaining the order how he loops?
thanks a lot for help, I tried all kind of variations with the OrderedDict module but I don’t know how to write the code to get it ordered. I’m pretty much a dictionary noob and trying for a few weeks now to get familiar with it.
big big thank you for your time.
Bastian
