Hey all, I`m working on an export tool that just preps the file to be exported. I need to rename all the mesh LODs to be a very specific object ID, so I open a window that prompts you to enter your object ID which is a random generated number from another tool we have. I’ve got most of it working, but I’ve run into a problem. When the object ID starts with a number, even though a print of the input says the proper ID, when the object is renamed, it will delete all numbers at the start. For instance, if the object ID is “2345-se3f-dhen”, then when the mesh is renamed it will be renamed to “_se3f_dhen” (underscores are on purpose). or, if the ID is “23fe4-dhfr-342d”, then it gets renamed to ‘fe4_dhfr_342d’, which deletes the 23 at the start of it. I’ve tried converted it all to a string, but that didnt seem to do anything. Any Ideas? Here’s the code.
#Prep For Export
class ExportPrep():
def __init__(self):
windowName = 'itemID'
if cmds.window(windowName, q=True, exists=True):
cmds.deleteUI(windowName)
itemID = cmds.window(windowName, title='Please Enter The Object ID')
cmds.columnLayout(parent=itemID)
cmds.text(' ')
self.objectIDInput = cmds.textFieldGrp(label='Object ID')
cmds.text(' ')
button_layout = cmds.rowColumnLayout(parent=itemID, numberOfColumns=4)
cmds.text(' ')
cmds.button('OK', c=self.PrepForExport, p=button_layout)
cmds.text(' ')
cmds.button('Cancel ...', c=self.closeWindow, p=button_layout)
cmds.showWindow(windowName)
def closeWindow(self, name):
#def testing(self, name):
def PrepForExport(self, name):
object_ID = cmds.textFieldGrp(self.objectIDInput, q=True, text=True)
object_ID = str(object_ID.replace('-', '_'))
cmds.delete('|Reference|Geometry')
#Select all the bones, then delete all the key frames
cmds.select('PelvisRoot', r=True)
cmds.select(all=True)
cmds.cutKey(cl=True)
cmds.parent(w=True)
cmds.select("|Geometry")
cmds.select(hi=True)
cmds.parent(w=True)
cmds.delete('|Reference')
cmds.delete('|Geometry')
print object_ID
#Rename all the LODs
lod0 = cmds.file(q=True, sn=True, shortName=True)[:-3] + '_LOD0'
lod1 = cmds.file(q=True, sn=True, shortName=True)[:-3] + '_LOD1'
lod2 = cmds.file(q=True, sn=True, shortName=True)[:-3] + '_LOD2'
cmds.select(lod0)
cmds.rename(object_ID + '_LOD0')
cmds.select(lod1)
cmds.rename(object_ID + '_LOD1')
cmds.select(lod2)
cmds.rename(object_ID + '_LOD2')
print object_ID
ExportPrep()
