I’m doing an exercise in Class design and I’m having some problems wrapping my head around a particular problem.
Here is some pseudo code that demonstrates the functionality I would like:
MyClass = Mesh('pCube1') # this class automatically adds a user-defined Boolean attribute, export, and creates a class property to manage it.
MyClass.export = True
MyClass.export
# Result: True
MyClass.export.lock = True # this fails
MyClass.export.lock
# Result: True
The snag I am hitting is when I try to Lock the Property.
# AttributeError: 'bool' object has no attribute 'lock'
It is my understanding that this is happening:
MyClass.export.lock = True > True.lock = True
How do I get the Property Class back instead of its value?
(the easy way) Dont’ use nested properties, use methods:
Class MyClass (object):
def __init__(self):
self._export = False;
self._lock_export = False;
def set_export(self, val):
if self._lock_export: raise RuntimeError ("Export value is locked")
self._export = val
def get_export(self):
return self._export
def lock_export(self):
self._lock_export = True
def unlock_export(self):
Same as (2) except that you can make the ‘export’ into a property:
def __init__(self):
@property
def export(self):
return self._export
@export.setter
self._export = val
If you’re really desperate for nested properties as in the original post, you can combine (1) and (3) so that the hidden inner object is always a LockableBool object:
# in the init, make sure the hidden _export field is a LockableBool(). I'm pretending 'val' is the actual true-false value of that class...
@export.setter
if self._lock_export.lock: raise RuntimeError ("Export value is locked")
self._export.value = val
… I should have mentioned that many people frown on the use of deeply nested properties in the first place. The theory is that they involve too much extra knowledge: the use has to know not only about the abilities of MyClass() but also those of LockableBool(), etc. However that’s one of those programmer flame war topics that will never end
