[Python/Api] Setting the active viewport
Hey All,
I’m working on a Playblasting tool, but am encountering an issue when running the playblast command itself,
What I’m doing:
Cloning the active viewport-
self.tempViewport = pm.modelPanel(tearOffCopy=self.activeView)
Setting the focus to the new script generated viewport
pm.setFocus(self.tempViewport)
Executing the playblast (Playblast command dosent let you name the viewport to Playblast from - it just takes the “active” view … which i assumed was the one with focus, apparently not! )
Any ideas on how to set the active view, via API or another method?
Cheers!
~ Joe :slight_smile:
It is the ‘model editor’ inside the model panel that need to be activated, using the modelEditor command.
It is probably should be something like:
pm.modelEditor( self.tempViewport, e = True, activeView = True )
Sadly just been trying that again - Excuse Psuedocode
pm.evalDeferred(self.setFocus())
def setFocus(self):
      self.tempModelEditor = self.tempViewport.getModelEditor()
      print pm.modelEditor(self.tempModelEditor, query=True, activeView=True)
      [ This yeilds False ]
      pm.modelEditor(self.tempModelEditor, edit=True, activeView=True)
      [ This yeilds True ]
      pm.evalDeferred(self.createPlayBlast(),lowestPriority=True)
But Maya still gets the # RuntimeError: no active view for playblast # when running through… :frowning:
This code snippet seems to work for me. It appears that playblast() is intelligent enough to work on the active panel (not the model editor):
import maya.cmds as pm
print "Current panel to get playblasted is: " + pm.getPanel(withFocus=True)
tempPanel = pm.modelPanel(tearOff=True)
print "Tear off panel is: "+ tempPanel
print "Playblast currently focused on panel: "+ pm.playblast(activeEditor=True)
pm.setFocus(tempPanel)
print "Now playblast focused on panel: " +pm.playblast(activeEditor=True)
pm.evalDeferred("pm.playblast()")
Phil
Hey Phil!
It appears the difference to what ive tried and your sample is you’re doing
pm.evalDeferred(“pm.playblast()”)
I was evalDeferring the function that contained the PlayBlast command, rather than the playblast command itself.
After making a monster string containing all the flag arguments to pass into the PlayBlast command ive got it working as above as well :slight_smile:
Cheers!
~ Joe
