I´m learning PySide becouse I´m writing an autorig. Now I´m in the UI creation.
I´m having some problems trying to change the button text when I click on the button.
The main reason is to get the seleted join name in the text for this button.
I guess it´s a minor thing, but I´m missing some concept I don´t realise, so a little bit of help It would be very handy.
I appreciate it.
Cheers
from PySide import QtGui
import maya.OpenMayaUI as mui
import shiboken
def getMayaWindow():
pointer = mui.MQtUtil.mainWindow()
return shiboken.wrapInstance(long(pointer), QtGui.QWidget)
def createUI():
objectName = 'testWin'
if cmds.window('testWin', exists = True):
cmds.deleteUI('testWin', wnd = True)
parent = getMayaWindow()
window = QtGui.QMainWindow(parent)
window.setObjectName(objectName)
window.setWindowTitle('Title')
mainWidget = QtGui.QWidget()
window.setCentralWidget(mainWidget)
verticalLayout = QtGui.QVBoxLayout(mainWidget)
layout2 = QtGui.QHBoxLayout()
verticalLayout.addLayout(layout2)
button = QtGui.QPushButton('None')
verticalLayout.addWidget(button)
button.clicked.connect(changeName)
window.show()
def changeName():
button.setText('22')
createUI()
“button” in changeName is out of scope. Make this a class and button a member variable
Could be possible a little illustrative example please?
Thanks a lot for your reply!!
class MyClass(object):
def __init__(self):
self._button = None
def createUI(self):
self._button = QtGui.QPushButton('Click me', self)
self._button.clicked.connect(self.clicked)
self._button.show()
def clicked(self):
self._button.setText('22')
cls = MyClass()
cls.createUI()
If you’re just playing around inside Maya script editor, you can do this as well.
From PySide import QtGui
mybutton = QtGui.QPushButton()
mybutton.show()
Now you can keep referring to mybutton to play with it.
mybutton.setText("Hello")
mybutton.setText("Hello World")
mybutton.hide()
mybutton.show()
def saysomething():
print "click click click"
mybutton.clicked.connect(saysomething)
And if the button goes behind Maya, you can pull it back to the top with mybutton.raise_()
if you want the method to adjust your button, you’ll have to pass the button as argument and you’ll be able to do something like this.
def changetext(elem, text):
elem.setText(text)
changetext(mybutton, "Change to this text.")
Of course when you’re developing an actual, functional UI you’ll want to wrap everything in a class.
Thank you so much for the examples! Now I´m starting a see the light!
import shiboken
class create_ui(object):
def __init__(self):
self._button = None
def check_win_exists(self):
def get_maya_window(self):
def UI(self):
layout = QtGui.QHBoxLayout()
verticalLayout.addLayout(layout)
self.group01 = QtGui.QGroupBox('ARPG Autorig')
self.group01.setLayout(verticalLayout)
#self._label1 = QtGui.QLabel('Select ARM Joint:')
#verticalLayout.addWidget(self._label1)
self._button = QtGui.QPushButton('Select Arm Root Joint')
verticalLayout.addWidget(self._button)
self._button.clicked.connect(self.getRoot)
#self._label2 = QtGui.QLabel('Select LEG Joint:')
#verticalLayout.addWidget(self._label2)
self._button2 = QtGui.QPushButton('Select Leg Root Joint')
verticalLayout.addWidget(self._button2)
self._button2.clicked.connect(self.getRoot)
#self._label3 = QtGui.QLabel('Select SPINE Joint:')
#verticalLayout.addWidget(self._label3)
self._button3 = QtGui.QPushButton('Select Spine Root Joint')
verticalLayout.addWidget(self._button3)
self._button3.clicked.connect(self.getRoot)
self._button4 = QtGui.QPushButton('Create Rig')
verticalLayout.addWidget(self._button4)
self._button4.setStyleSheet('QPushButton{background-color: red;}')
self.group01.show()
#window.show()
def getRoot(self):
#check which button is pressed and change the label for this button
#and return the name of this selected bone
root_jnt = cmds.ls(sl=True)
self._button.setText(root_jnt[0])
self._button.setStyleSheet('QPushButton{background-color: green}')
return root_jnt
cls = create_ui()
cls.get_maya_window()
cls.check_win_exists()
cls.UI()
t = cls.getRoot()
