Hi, i don’t know if here is the right place to post, but i have an issue with an old maya plugin called bSkinSaver which uses pySide in order to run and as i understand now maya has pySide 2.
So i am in a situation that i really need this script but i don’t know what to do.
I have tried many things(i am not an expert of python) replacing Pyside with Pyside2 shiboken with shiboken 2 QtCore and QtGui with QtWidgets but still nothing happens. I am able at the moment to run it without an error but when i am calling the script errors pops, such as # Error: AttributeError: file <maya console> line 43: 'module' object has no attribute 'WindowStaysOnTopHint' #
Here is the original script:
Tool for saving and loading skinWeights in Maya
(c) 2013 - 2015 by Thomas Bittner
thomasbittner@hotmail.de
source the file and then run: showUI()
import maya.OpenMayaMPx as OpenMayaMPx
import maya.OpenMaya as OpenMaya
import maya.OpenMayaAnim as OpenMayaAnim
import maya.mel
import sys
import maya.OpenMayaUI as mui
from PySide import QtCore, QtGui
import shiboken
def showUI():
global mainWin
mainWin = bSkinSaverUI()
mainWin.show()
def getMayaWindow():
ptr = mui.MQtUtil.mainWindow()
return shiboken.wrapInstance(long(ptr), QtGui.QWidget)
class bSkinSaverUI(QtGui.QDialog):
def __init__(self, parent=getMayaWindow()):
super(bSkinSaverUI, self).__init__(parent, QtCore.Qt.WindowStaysOnTopHint)
tab_widget = QtGui.QTabWidget()
objectsTab = QtGui.QWidget()
verticesTab = QtGui.QWidget()
tab_widget.addTab(objectsTab, "Objects")
tab_widget.addTab(verticesTab, "Vertices")
self.descLabel = QtGui.QLabel("(C) 2015 by Thomas Bittner", parent=self)
self.setWindowTitle('bSkinSaver 1.0')
self.objectsFileLine = QtGui.QLineEdit('', parent=self)
self.selectObjectsFileButton = QtGui.QPushButton("Set File", parent=self)
self.saveObjectsButton = QtGui.QPushButton("Save Weights from selected Objects", parent=self)
self.loadObjectsButton = QtGui.QPushButton("Load", parent=self)
self.loadObjectsSelectionButton = QtGui.QPushButton("Load to Selected Object", parent=self)
objectsLayout = QtGui.QVBoxLayout(objectsTab)
objectsLayout.setAlignment(QtCore.Qt.AlignTop)
objectsLayout.setSpacing(3)
objectsFileLayout = QtGui.QBoxLayout(QtGui.QBoxLayout.LeftToRight)
objectsFileLayout.addWidget(self.objectsFileLine)
objectsFileLayout.addWidget(self.selectObjectsFileButton)
objectsLayout.addLayout(objectsFileLayout)
objectsButtonLayout = QtGui.QBoxLayout(QtGui.QBoxLayout.TopToBottom)
objectsButtonLayout.setSpacing(0)
objectsButtonLayout.addWidget(self.saveObjectsButton)
objectsButtonLayout.addWidget(self.loadObjectsButton)
objectsButtonLayout.addWidget(self.loadObjectsSelectionButton)
objectsLayout.addLayout(objectsButtonLayout)
self.verticesFileLine = QtGui.QLineEdit('', parent=self)
self.selectVerticesFileButton = QtGui.QPushButton("Set File", parent=self)
self.saveVerticesButton = QtGui.QPushButton("Save Weights from selected Vertices", parent=self)
self.loadVerticesButton = QtGui.QPushButton("Load onto selected Object", parent=self)
verticesLayout = QtGui.QVBoxLayout(verticesTab)
verticesLayout.setAlignment(QtCore.Qt.AlignTop)
verticesLayout.setSpacing(3)
verticesFileLayout = QtGui.QBoxLayout(QtGui.QBoxLayout.LeftToRight)
verticesFileLayout.addWidget(self.verticesFileLine)
verticesFileLayout.addWidget(self.selectVerticesFileButton)
verticesLayout.addLayout(verticesFileLayout)
verticesButtonLayout = QtGui.QBoxLayout(QtGui.QBoxLayout.TopToBottom)
verticesButtonLayout.setSpacing(0)
verticesButtonLayout.addWidget(self.saveVerticesButton)
verticesButtonLayout.addWidget(self.loadVerticesButton)
verticesLayout.addLayout(verticesButtonLayout)
self.layout = QtGui.QBoxLayout(QtGui.QBoxLayout.TopToBottom, self)
self.layout.addWidget(tab_widget)
self.layout.addWidget(self.descLabel)
self.resize(400, 10)
#select files
self.connect(self.selectObjectsFileButton, QtCore.SIGNAL("clicked()"), self.selectObjectsFile)
self.connect(self.selectVerticesFileButton, QtCore.SIGNAL("clicked()"), self.selectVerticesFile)
self.connect(self.saveObjectsButton, QtCore.SIGNAL("clicked()"), self.saveObjects)
self.connect(self.loadObjectsButton, QtCore.SIGNAL("clicked()"), self.loadObjects)
self.connect(self.loadObjectsSelectionButton, QtCore.SIGNAL("clicked()"), self.loadObjectsSelection)
self.connect(self.saveVerticesButton, QtCore.SIGNAL("clicked()"), self.saveVertices)
self.connect(self.loadVerticesButton, QtCore.SIGNAL("clicked()"), self.loadVertices)
def selectObjectsFile(self):
fileResult = cmds.fileDialog2()
if fileResult != None:
self.objectsFileLine.setText(fileResult[0])
def selectVerticesFile(self):
self.verticesFileLine.setText(fileResult[0])
def loadObjects(self):
bLoadSkinValues (False, str(self.objectsFileLine.text()))
def loadObjectsSelection(self):
bLoadSkinValues (True, str(self.objectsFileLine.text()))
def saveObjects(self):
bSaveSkinValues(str(self.objectsFileLine.text()))
def loadVertices(self):
bLoadVertexSkinValues (str(self.verticesFileLine.text()))
def saveVertices(self):
bSaveVertexSkinValues(str(self.verticesFileLine.text()))
bSkinPath = OpenMaya.MDagPath()
def bFindSkinCluster(objectName):
it = OpenMaya.MItDependencyNodes(OpenMaya.MFn.kSkinClusterFilter)
while not it.isDone():
fnSkinCluster = OpenMayaAnim.MFnSkinCluster(it.item())
fnSkinCluster.getPathAtIndex(0,bSkinPath)
if OpenMaya.MFnDagNode(bSkinPath.node()).partialPathName() == objectName or OpenMaya.MFnDagNode(OpenMaya.MFnDagNode(bSkinPath.node()).parent(0)).partialPathName() == objectName:
return it.item()
it.next()
return False
def bLoadVertexSkinValues(inputFile):
line = ''
joints = []
weights = []
splittedStrings = []
splittedWeights = []
weightDoubles = OpenMaya.MDoubleArray()
selectionList = OpenMaya.MSelectionList()
vertexCount = 0;
OpenMaya.MGlobal.getActiveSelectionList( selectionList );
node = OpenMaya.MDagPath()
component = OpenMaya.MObject()
selectionList.getDagPath( 0, node, component );
if not node.hasFn(OpenMaya.MFn.kTransform):
print 'select a skinned object'
NewTransform = OpenMaya.MFnTransform (node)
if not NewTransform.childCount() or not NewTransform.child(0).hasFn(OpenMaya.MFn.kMesh):
print 'select a skinned object..'
mesh = NewTransform.child(0);
objectName = OpenMaya.MFnDagNode(mesh).name()
skinCluster = bFindSkinCluster(objectName)
if not skinCluster.hasFn(OpenMaya.MFn.kSkinClusterFilter):
fnSkinCluster = OpenMayaAnim.MFnSkinCluster(skinCluster)
input = open(inputFile, 'r')
joints = []
weightLines = []
filePosition = 0
while True:
line = input.readline().strip()
if not line:
break
if filePosition == 0:
vertexCount = int(line)
filePosition = 1
elif filePosition == 1:
if not line.startswith("========"):
joints.append(line)
else:
filePosition = 2;
elif filePosition == 2:
weightLines.append(line)
if OpenMaya.MItGeometry(node).count() != vertexCount:
print "vertex counts don't match, result might be bad"
# joints..
influenceArray = OpenMaya.MDagPathArray()
influenceStringArray = []
influenceMapArray = OpenMaya.MIntArray()
jointsMapArray = OpenMaya.MIntArray()
infCount = fnSkinCluster.influenceObjects(influenceArray)
for i in range(infCount):
influenceStringArray.append(OpenMaya.MFnDagNode(influenceArray[i]).name())
influenceMapArray.append(-1)
for k in range(len(joints)):
if influenceStringArray[i] == joints[k]:
influenceMapArray[i] = k
for i in range(len(joints)):
jointsMapArray.append(-1);
allInfluencesInScene = True
influenceInScene = False
for k in range(len(influenceStringArray)):
if influenceStringArray[k] == joints[i]:
influenceInScene = True
jointsMapArray[i] = k
if not influenceInScene:
allInfluencesInScene = False
print joints[i], ' is missing in the skinCluster'
if not allInfluencesInScene:
print 'There are influences missing'
return
extraInfluencesCount = 0
for i in range(len(influenceStringArray)):
jointInInfluences = False
if joints[k] == influenceStringArray[i]:
jointInInfluences = True
if not jointInInfluences:
jointsMapArray.append(i)
extraInfluencesCount += 1
#load points
fnVtxComp = OpenMaya.MFnSingleIndexedComponent()
vtxComponents = OpenMaya.MObject()
vtxComponents = fnVtxComp.create( OpenMaya.MFn.kMeshVertComponent )
for i in range(len(weightLines)):
splittedStrings = weightLines[i].split(':');
if len(splittedStrings) > 1:
fnVtxComp.addElement(int(splittedStrings[0]))
splittedWeights = splittedStrings[1].split(' ')
for k in range(len(splittedWeights)):
weightDoubles.append(float(splittedWeights[k]))
weightDoubles += [0] * extraInfluencesCount
#SET WEIGHTS
fnSkinCluster.setWeights(bSkinPath, vtxComponents, jointsMapArray, weightDoubles, 0)
# select the vertices
pointSelectionList = OpenMaya.MSelectionList()
pointSelectionList.add(OpenMaya.MDagPath(node),vtxComponents);
OpenMaya.MGlobal.setActiveSelectionList(pointSelectionList);
def bSaveVertexSkinValues(inputFile):
print 'saving Vertex skinWeights.. '
selection = OpenMaya.MSelectionList()
OpenMaya.MGlobal.getActiveSelectionList( selection );
iterate = OpenMaya.MItSelectionList(selection);
while not iterate.isDone():
dagPath = OpenMaya.MDagPath()
component = OpenMaya.MObject();
iterate.getDagPath(dagPath, component);
skinCluster = bFindSkinCluster(OpenMaya.MFnDagNode(dagPath).partialPathName())
fnSkinCluster = OpenMayaAnim.MFnSkinCluster(skinCluster);
iterate.next()
if skinCluster.hasFn(OpenMaya.MFn.kSkinClusterFilter):
output = open(inputFile, 'w')
output.write(str(OpenMaya.MItGeometry(bSkinPath).count()) + '\n')
vtxComponents = OpenMaya.MObject();
vtxComponents = fnVtxComp.create( OpenMaya.MFn.kMeshVertComponent );
WeightArray = OpenMaya.MFloatArray()
meshIter = OpenMaya.MItMeshVertex ( dagPath, component)
while not meshIter.isDone():
fnVtxComp.addElement( meshIter.index());
meshIter.next()
vertexCount = meshIter.count();
scriptUtil = OpenMaya.MScriptUtil()
infCountPtr = scriptUtil.asUintPtr()
fnSkinCluster.getWeights(bSkinPath, vtxComponents, WeightArray, infCountPtr)
infCount = OpenMaya.MScriptUtil.getUint(infCountPtr)
weightCheckArray = []
weightCheckArray.append(False)
for i in range(vertexCount):
for k in range(infCount):
if not weightCheckArray[k] and WeightArray[((i * infCount) + k)]:
weightCheckArray[k] = True
#joints..
InfluentsArray = OpenMaya.MDagPathArray()
fnSkinCluster.influenceObjects(InfluentsArray);
if (weightCheckArray[i]):
output.write(OpenMaya.MFnDagNode(InfluentsArray[i]).name() + '\n')
output.write('============\n')
counter = 0;
weightArrayString = []
meshIter = OpenMaya.MItMeshVertex (dagPath, component)
weightArrayString = str(meshIter.index()) + ':'
if weightCheckArray[k] == True:
weightArrayString += str(WeightArray[(counter * infCount) + k]) + ' '
output.write(weightArrayString + '\n')
counter += 1
meshIter.next()
output.close()
iterate.next()
def bSaveSkinValues(inputFile):
OpenMaya.MGlobal.getActiveSelectionList(selection)
iterate.getDagPath (node, component)
print OpenMaya.MFnDagNode(node).name() + ' is not a Transform node (need to select transform node of polyMesh)'
else:
objectName = OpenMaya.MFnDagNode(node).name()
newTransform = OpenMaya.MFnTransform(node)
for childIndex in range(newTransform.childCount()):
childObject = newTransform.child(childIndex)
if childObject.hasFn(OpenMaya.MFn.kMesh) or childObject.hasFn(OpenMaya.MFn.kNurbsSurface) or childObject.hasFn(OpenMaya.MFn.kCurve):
skinCluster = bFindSkinCluster(OpenMaya.MFnDagNode(childObject).partialPathName())
if skinCluster is not False:
influentsCount = influenceArray.length()
#output.write(bSkinPath.partialPathName() + '\n')
output.write(objectName + '\n')
for k in range(influentsCount):
jointTokens = str(influenceArray[k].fullPathName()).split('|')
jointTokens = jointTokens[len(jointTokens)-1].split(':')
output.write(jointTokens[len(jointTokens)-1] + '\n')
vertexIter = OpenMaya.MItGeometry(bSkinPath)
saveString = ''
counterValue = 0
while not vertexIter.isDone():
counterValue = counterValue + 1
vertex = vertexIter.component()
weightArray = OpenMaya.MDoubleArray()
fnSkinCluster.getWeights(bSkinPath, vertex, weightArray, infCountPtr)
saveString = ''
for j in range(OpenMaya.MScriptUtil.getUint(infCountPtr)):
saveString += str(weightArray[j])
saveString += ' '
output.write(saveString + '\n')
vertexIter.next()
output.write('\n')
iterate.next()
output.close()
print "done saving weights"
def bSkinObject(objectName, joints, weights):
if not cmds.objExists(objectName):
print objectName, " doesn't exist - skipping. "
return
allInfluencesInScene = True;
jointsCheck = []
jointsCheck = joints[i]
sceneJointTokens = []
fileJointTokens = []
it = OpenMaya.MItDependencyNodes ( OpenMaya.MFn.kJoint);
# quick check:
for jointIndex in range(len(joints)):
jointHere = False;
sceneJointTokens = str(OpenMaya.MFnDagNode(it.item()).fullPathName()).split('|')
if str(joints[jointIndex]) == str(sceneJointTokens[len(sceneJointTokens) - 1]):
jointHere = True;
it.next()
if not jointHere:
allInfluencesInScene = False;
print 'missing influence: ', joints[jointIndex]
print objectName, " can't be skinned because of missing influences."
return
#maya.mel.eval("undoInfo -st 0")
if type(bFindSkinCluster(objectName)) != type(True):
maya.mel.eval("DetachSkin " + objectName)
cmd = "select "
cmd += " " + joints[i]
cmd += " " + objectName
maya.mel.eval(cmd)
maya.mel.eval("skinCluster -tsb -mi 10");
maya.mel.eval("select `listRelatives -p " + objectName + "`");
maya.mel.eval("refresh")
#maya.mel.eval("undoInfo -st 1")
fnSkinCluster.getPathAtIndex(fnSkinCluster.indexForOutputConnection(0),bSkinPath)
weightStrings = []
vertexIter = OpenMaya.MItGeometry (bSkinPath)
singleIndexed = True;
fnVtxCompDouble = OpenMaya.MFnDoubleIndexedComponent()
if bSkinPath.node().apiType() == OpenMaya.MFn.kMesh:
elif bSkinPath.node().apiType() == OpenMaya.MFn.kNurbsSurface:
singleIndexed = False
vtxComponents = fnVtxCompDouble.create( OpenMaya.MFn.kSurfaceCVComponent )
elif bSkinPath.node().apiType() == OpenMaya.MFn.kNurbsCurve:
vtxComponents = fnVtxComp.create( OpenMaya.MFn.kCurveCVComponent )
#mapping joint-indices
influenceIndices = OpenMaya.MIntArray()
checkInfluences = []
for k in range(InfluentsArray.length()):
checkInfluences.append(0)
influenceIndices.append(-1)
fileJointTokens = joints[i].split('|')
sceneJointTokens = str(OpenMaya.MFnDagNode(InfluentsArray[k]).fullPathName()).split('|')
if fileJointTokens[len(fileJointTokens) - 1] == sceneJointTokens[len(sceneJointTokens) - 1]: # changed from joints
influenceIndices[i] = k
checkInfluences[k] = 1
counterValue = 0;
if not singleIndexed:
currentU = 0
currentV = 0
cvsU = OpenMaya.MFnNurbsSurface(bSkinPath.node()).numCVsInU()
cvsV = OpenMaya.MFnNurbsSurface(bSkinPath.node()).numCVsInV()
formU = OpenMaya.MFnNurbsSurface(bSkinPath.node()).formInU()
formV = OpenMaya.MFnNurbsSurface(bSkinPath.node()).formInV()
if formU == 3:
cvsU -= 3
if formV == 3:
cvsV -= 3
weightStrings = []
if singleIndexed:
fnVtxComp.addElement(counterValue)
else:
fnVtxCompDouble.addElement(currentU, currentV)
currentV += 1;
if currentV >= cvsV:
currentV = 0
currentU += 1
weightStrings = weights[counterValue].split(' ');
for i in range(len(weightStrings)):
weightDoubles.append(float(weightStrings[i]))
counterValue += 1
vertexIter.next()
#SET WEIGHTS
print "setting weights for ", objectName
fnSkinCluster.setWeights(bSkinPath, vtxComponents, influenceIndices,weightDoubles, 0)
#Maya.mel.eval("skinPercent -normalize true " + fnSkinCluster.name() + " " + objectName)
influenceIndices.clear();
weightDoubles.clear();
def bLoadSkinValues(loadOnSelection, inputFile):
joints = []
weights = []
PolygonObject = ""
if loadOnSelection == True:
OpenMaya.MGlobal.getActiveSelectionList(selectionList)
if selectionList.length():
if node.hasFn(OpenMaya.MFn.kTransform):
if NewTransform.childCount():
if NewTransform.child(0).hasFn(OpenMaya.MFn.kMesh):
PolygonObject = str(OpenMaya.MFnDagNode(NewTransform.child(0)).partialPathName())
if loadOnSelection and len(PolygonObject) == 0:
print "You need to select a polygon object"
return
FilePosition = 0
while True:
if not line:
break
line = line.strip()
if FilePosition is not 0:
if not line.startswith("============"):
if FilePosition is 1:
joints.append(line)
elif FilePosition is 2:
if len(line) > 0:
weights.append(line)
else:
bSkinObject(PolygonObject, joints, weights)
PolygonObject = ""
joints = []
weights = []
FilePosition = 0
break
else: # it's ========
FilePosition = 2
else: #FilePosition is 0
if not loadOnSelection:
PolygonObject = line
FilePosition = 1;
if cmds.objExists(PolygonObject):
maya.mel.eval("select " + PolygonObject)
