[PYSIDE] shortCut behavior on buttons in different tabs
I have a UI with a few Tabs and in these tabs I have some buttons and I’ve assigned these buttons shortCuts.
My problem is that the shortCuts only seem to work when the Tab is active or being shown. If I go to another tab that same shortCut does not want to work. It’s only when I activate the tab does the shortCut work.
Any suggestions on getting the behavior to work across all tabs?
Cheers,
-Sean
Forget it. I’m going to go down a different route.
Thinking of doing some module inspection and setting up Maya hotkey namedCommands on the fly.
That way the UI doesn’t need to be loaded at runtime.
So I thought I’d share a bit of code I came up with. Like I said above I needed to create shorctCuts for my buttons and menus but instead of using shortCuts on buttons I’d rather have Maya shortCuts for the ACTUAL function call.
I ended up creating an EchoCommand decorator and used this decorator for each button function call.
Here I have a simple function say stored in myModule.py:
def saySomething(s):
    print "You said {}".format(s)
For my button I have this.
self.myButton.clicked.connect(lambda *args: self.saySomething("I'm handsome"))
So you click the button and it prints “You said I’m handsome”. Thanks, you’re so nice!
Now here is the decorator code (I’ve been putting all my decorator code in a decorator.py file and import the commands I need)
class EchoCommand(object):
    Similar to Maya's echo commands
    Prints out the module and function with arguments
    def __init__(self, function):
        self.function = function
        self.function_call = self.function.__name__
        self.module = inspect.getmodule(self.function).__name__
    def echo(self, *arguments, **namedArguments):
        print "from {} import {}".format(self.module, self.function_call)
        print "{}{}".format(self.function.func_name, arguments)
        self.function.__call__(*arguments, **namedArguments)
def d_echoCommand(function):
    Echo Command
    return EchoCommand(function).echo
Let’s implement the decorator now:
@d_echoCommand
Now when you hit the button you should get the echoed command
from myModule import saySomething
saySomething("I'm handsome",)
So now the user can take that bit of code and create a Maya Hotkey, make it repeatable or run it manually.
Hope you find it helpful!
Cheers,
-Sean
