Hello guys,
I’m having a little problem on a tool I’m developping.
I have a progress bar that I use to display the progress of file copying or moving.
In one of my function, I want to do the following :
oldPath = sorted([os.path.join(self.localPath, 'old', v) for v in os.listdir(self.localPath) if not 'old' in v])[-1]
self._print('OLD PATH :'+oldPath)
if not os.path.exists(oldPath):
os.makedirs(oldPath)
self._print('old folder created !')
oldSrcPath = os.path.join(self.localPath, currentLocalVersion)
# Thread for moving files :
print '#'*50
print 'SRC FOR MOVING : ', oldSrcPath
print 'DEST FOR MOVING :', oldPath
print '#'*50
self.moveFilesThread(oldSrcPath, oldPath)
self._print('Moving done !')
localVersionName = datetime.datetime.now().strftime('%Y%m%d%H%M%S')+'_'+str(boardVersion['sg_version']).zfill(3)
self.dstPath = os.path.join(self.dstPath, localVersionName)
print '-'*50
print 'SRC COPY :', self.srcPath
print 'DEST PATH :', self.dstPath
# Then launch a new thread with the actual good copy
self.copyFilesThread(self.srcPath, self.dstPath)
print 'Back in main thread yeah !'
My self.moveFilesThread(oldSrcPath, oldPath) calls this function :
@QtCore.Slot(bool)
def moveFilesThread(self, srcPath, dstPath):
Launch thread for
:param srcPath:
:param dstPath:
:return:
if not self.moveInProgress or not self.moveInProgress.isRunning():
self.progressBar.reset()
self.progressBar.setRange(0,100)
self.progressBar.setValue(0)
# Starting the thread
self.moveInProgress = GetDataThread(srcPath, dstPath, move=True)
self.moveInProgress.info.connect(self.updateProgress)
self.moveInProgress.complete.connect(self.copyComplete)
self.moveInProgress.status.connect(self.updateStatus)
self.moveInProgress.start()
# self.moveInProgress.terminate()
# self.moveInProgress.wait()
print 'Moving Thread Launched !'
self.work_btn.setEnabled(False)
I would like this thread to be finished before my second self.copyFilesThread to be executed.
I tried using wait(), but it seems my second thread is not executed.
My run() in my “worker class” looks like this :
def run(self, *args, **kwargs):
:param args:
:param kwargs:
:return:
filesToCopy = self.getFiles(self.srcPath, self.destPath)
numFiles = len(filesToCopy)
i = 1
start = timeit.default_timer()
for src,dest in filesToCopy.items():
if not os.path.exists(os.path.dirname(dest)):
os.makedirs(os.path.dirname(dest))
if self.move:
print("Moving "+str(i)+"/"+str(numFiles)+" files")
statusText = "Moving "+str(i)+"/"+str(numFiles)+" files"
shutil.move(src, dest)
else:
print("Copying "+str(i)+"/"+str(numFiles)+" files")
statusText = "Copying "+str(i)+"/"+str(numFiles)+" files"
shutil.copy2(src, dest)
self.info.emit((i*100)/numFiles) # envoi du signal de progression
self.status.emit(statusText)
i += 1
if self.move:
shutil.rmtree(self.srcPath)
self.complete.emit(self.error)
elapsed = timeit.default_timer() - start
print 'Done in ', elapsed, 'seconds ! Ain\'t that cool ??'
My problem is while i’m moving files I get updates of the copying whilst i would like to end the moving part before starting to copy.
Anyone has any idea how to achieve that ?
