[PyMel] MayaNode error on PyUI class
Hi Guys,
I am trying to get the parent layouts of the time control, but am getting an error and I am unsure why.
import pymel.core as pm
defaultTimeControl = pm.lsUI(type ='timeControl')[0]
print defaultTimeControl
print type(defaultTimeControl)
listTimeParents = pm.listRelatives(defaultTimeControl, allParents = True)
yields this information;
MayaWindow|toolBar6|MainTimeSliderLayout|formLayout9|frameLayout2|timeControl1
<class 'pymel.core.uitypes.PyUI'>
but gives the following error;
# Error:
#   File "<maya console>", line 6, in <module>
#   File "C:\Program Files\Autodesk\Maya2013\Python\Lib\site-packages\pymel\core\general.py", line 892, in listRelatives
#     results = map(PyNode, _util.listForNone(cmds.listRelatives(*args, **kwargs)))
#   File "C:\Program Files\Autodesk\Maya2013\Python\Lib\site-packages\pymel\internal\pmcmds.py", line 140, in wrappedCmd
#     raise pymel.core.general._objectError(obj)
# MayaNodeError: Maya Node does not exist: u'MayaWindow|toolBar6|MainTimeSliderLayout|formLayout9|frameLayout2|timeControl1' #
Can anyone explain why this is please? Sorry for a noobish question :slight_smile:
Thanks, Chris
listRelatives only works with DAG objects. ui control/layout commands have flags for accessing the parent of a control/layout.
If you want to use pymel:
timeParent = defaultTimeControl.getParent()
Or using the standard commands:
defaultTimeControl = cmds.lsUI(type ='timeControl')[0]
timeParent = cmds.timeControl(defaultTimeControl, query=True, parent=True)
Thanks capper!
I knew about .parent() method, what I am tring to put the whole parent hierarchy into a list. What would be the best way to do that?
Thanks for the reply!
Chris
You mean you want every parent as a separate item in a list?
pymel:
widget = pm.lsUI(type='timeControl')[0]
parents = []
while True:
    widget = widget.getParent()
    if not widget:
        break
    parents.append(widget)
maya.cmds
widget = cmds.lsUI(type='timeControl')[0]
parents = []
while '|' in widget:
    widget = widget.rsplit('|', 1)[0]
