#### Start up ####
import pymel.core as pm
class TestWin():
# UI vars
titleVar = "TEST"
windowX = 300 # Window width
windowY = 688 # Window height
winTestWin = "TestWin_win"
btnAddX = 36 # Add button (advanced mode)
btnClrX = 41 # Clear button (advanced mode)
btnRemX = 54 # Remove button (advanced mode)
btnW = 61 # Normal button width
btnW2 = 118 # Large button width
colSpacing1 = 20 # Tab 2 column1 spacing
colSpacing2 = 40 # Tab 2 column2 spacing
colSpacing3 = 10 # Tab 2 column3 spacing
frameMargin = 10 # Frame margin
objCol = (windowX / 2) # Column width in advanced mode
objListY = 215 # Height of object list
radCol1 = 50 # Radio button - column 1 width
radCol2 = 50 # Radio button - column 2 width
# Object list
itemList = []
## Initialize
def __init__(self):
# Option vars. Create new if they don't exist yet
if not ( pm.optionVar( exists="TestWinoptVarX" )):
pm.optionVar( intValue=("TestWinoptVarX", 256) )
if not ( pm.optionVar( exists="TestWinoptVarY" )):
pm.optionVar( intValue=("TestWinoptVarY", 256) )
if not ( pm.optionVar( exists="TestWinoptVarPath" )):
pm.optionVar( stringValue=("TestWinoptVarPath", "") )
if not ( pm.optionVar( exists="TestWinoptVarPadding" )):
pm.optionVar( intValue=("TestWinoptVarPadding", 0) )
if not ( pm.optionVar( exists="TestWinoptVarFormat" )):
pm.optionVar( intValue=("TestWinoptVarFormat", 1 ) )
# Create UI
self.createUI()
self.updateUI(-1)
## User-interface
# Close window
def closeUI(self):
pm.deleteUI( self.winTestWin )
## Create UI layout
def createUI(self):
# Check for window duplicate
if pm.window( self.winTestWin, exists=True ):
# Main window
window = pm.window(
self.winTestWin,
maximizeButton=True,
minimizeButton=True,
sizeable=False,
title=self.titleVar,
widthHeight=(self.windowX, self.windowY)
# Create main form layout
self.formMain = pm.formLayout()
self.formFrames = pm.formLayout(parent=self.formMain)
## Options frame
self.frameOptions = pm.frameLayout(
collapsable=False,
collapse=False,
label="Options",
marginHeight=self.frameMargin,
marginWidth=self.frameMargin,
parent=self.formFrames,
width=self.windowX,
# Options layout
self.colOptions = pm.columnLayout(
adjustableColumn=True,
columnAlign="left",
rowSpacing=6,
parent=self.frameOptions,
# Options controls
self.outPath = pm.textFieldButtonGrp(
"filePathField",
buttonCommand=lambda *args: self.browse(),
buttonLabel="Browse...",
changeCommand=lambda *args: self.updateUI(2),
columnAttach3=["left", "left", "right"],
columnWidth3=[45, 144, 20],
label="Path:",
parent=self.colOptions,
text=pm.optionVar( query="TestWinoptVarPath" ),
width=252
self.mapSizeX = pm.intSliderGrp(
"sliderX",
changeCommand=lambda *args: self.updateUI(0),
columnAttach3=["left", "left", "left"],
columnWidth3=[45, 35, 45],
dragCommand=lambda *args: self.updateUI(0),
field=True,
fieldStep=32,
label="Size X:",
max=8192,
min=32,
sliderStep=32,
step=32,
value=pm.optionVar( query="TestWinoptVarX" ),
width=252
self.mapSizeY = pm.intSliderGrp(
"sliderY",
changeCommand=lambda *args: self.updateUI(1),
dragCommand=lambda *args: self.updateUI(1),
field=True,
fieldStep=32,
label="Size Y:",
max=8192,
min=32,
sliderStep=32,
step=32,
value=pm.optionVar( query="TestWinoptVarY" ),
width=252
self.padding = pm.intSliderGrp(
"sliderPadding",
changeCommand=lambda *args: self.updateUI(3),
dragCommand=lambda *args: self.updateUI(3),
field=True,
fieldStep=1,
label="Padding:",
max=16,
min=0,
sliderStep=1,
step=1,
value=pm.optionVar( query="TestWinoptVarPadding" ),
width=252
self.fileFormat = pm.optionMenuGrp(
"fileFormat",
changeCommand=lambda *args: self.updateUI(4),
columnAttach2=["left", "left"],
columnWidth2=[45, 196],
label="Format:",
width=241,
# File format list on Machintosh
if ( pm.about(macOS=True) ):
pm.menuItem( label="Maya IFF" )
pm.menuItem( label="JPEG" )
pm.menuItem( label="MacPaint" )
pm.menuItem( label="PSD" )
pm.menuItem( label="PNG" )
pm.menuItem( label="Quickdraw" )
pm.menuItem( label="Quickdraw Image" )
pm.menuItem( label="SGI" )
pm.menuItem( label="TGA" )
pm.menuItem( label="TIFF" )
pm.menuItem( label="BMP" )
# File format list on Windows
else:
imfKey = ""
i = 0
# Query available image formats
imfPlugins = pm.imfPlugins( query=True )
# Maya IFF always available
# Display queried image formats
for i in xrange( 0, len(imfPlugins) ):
imfKey = pm.imfPlugins( imfPlugins[i], query=True, key=True )
if ( pm.imfPlugins( imfKey, query=True, writeSupport=True ) and not
pm.imfPlugins( imfKey, query=True, multiFrameSupport=True ) and
imfKey != "maya" ):
pm.menuItem( label=imfPlugins[i] )
# Select file format from optionVar
pm.optionMenuGrp(
"fileFormat",
edit=True,
select=pm.optionVar( query="TestWinoptVarFormat" )
self.radGrpOptions = pm.radioButtonGrp(
changeCommand=lambda *args: self.updateUI(-1),
columnWidth2=[self.radCol1, self.radCol2*2],
label="Method: ",
labelArray2=["Simple", "Advanced"],
numberOfRadioButtons=2,
select=pm.optionVar["unfoldMethod_NSUV"],
vertical=True,
## Objects frame. Simple mode
self.frameObjects1 = pm.frameLayout(
collapsable=False,
collapse=False,
label="Objects",
width=self.windowX,
# Objects list - Simple mode
self.objListSimple = pm.textScrollList(
"objListSimple",
allowMultiSelection=True,
# deleteKeyCommand=lambda *args: ???(), ## WARN
height=self.objListY,
parent=self.frameObjects1,
width=(self.windowX-self.frameMargin*2),
# Object buttons - Simple mode
self.formBtnsSimple = pm.formLayout(parent=self.frameObjects1)
self.btnAddSimple = pm.button(
command=lambda *args: self.updateObjList(),
label="Add",
parent=self.formBtnsSimple,
self.btnRemSimple = pm.button(
label="Remove",
self.btnClrSimple = pm.button(
label="Clear",
# Layout object buttons form - Simple mode
pm.formLayout(
self.formBtnsSimple, edit=True,
attachForm=[
(self.btnAddSimple, "left", 5),
(self.btnAddSimple, "bottom", 5),
(self.btnRemSimple, "bottom", 5),
(self.btnClrSimple, "right", 5),
(self.btnClrSimple, "bottom", 5),
attachPosition=[
(self.btnAddSimple, "right", 3, 33),
(self.btnRemSimple, "left", 2, 33),
(self.btnRemSimple, "right", 3, 66),
(self.btnClrSimple, "left", 2, 66),
attachNone=[
(self.btnAddSimple, "top"),
(self.btnRemSimple, "top"),
(self.btnClrSimple, "top"),
## Objects frame. Advanced mode
self.frameObjects2 = pm.frameLayout(
collapsable=False,
collapse=False,
label="Objects",
width=self.windowX,
# Object lists row layouts - Advanced mode
self.rowObjLabels = pm.rowLayout(
columnAttach=[1, "right", 0],
columnWidth2=[self.objCol/2, self.objCol/2],
numberOfColumns=2,
parent=self.frameObjects2,
width=(self.windowX/2 - self.frameMargin),
self.rowObjList = pm.rowLayout(
numberOfColumns=2,
self.rowObjBtn = pm.rowLayout(
numberOfColumns=2,
# Objects labels - Advanced mode
self.txtObjLab1 = pm.text(
align="left",
label="Lowpoly",
parent=self.rowObjLabels,
self.txtObjLab2 = pm.text(
align="left",
label="Highpoly",
# Objects lists - Advanced mode
self.objListAdv1 = pm.textScrollList(
"objListAdv1",
parent=self.rowObjList,
width=(self.windowX/2 - (self.frameMargin) - 2),
self.objListAdv2 = pm.textScrollList(
"objListAdv2",
# Object buttons form - Advanced mode
self.formBtns1 = pm.formLayout(
parent=self.rowObjBtn,
self.formBtns2 = pm.formLayout(
# Object buttons
self.btnAddAdv1 = pm.button(
label="Add",
parent=self.formBtns1,
width=self.btnAddX,
self.btnAddAdv2 = pm.button(
label="Add",
parent=self.formBtns2,
width=self.btnAddX,
self.btnRemAdv1 = pm.button(
label="Remove",
width=self.btnRemX,
self.btnRemAdv2 = pm.button(
label="Remove",
width=self.btnRemX,
self.btnClrAdv1 = pm.button(
label="Clear",
width=self.btnClrX,
self.btnClrAdv2 = pm.button(
label="Clear",
width=self.btnClrX,
# Layout object buttons forms - Advanced mode
pm.formLayout(
self.formBtns1, edit=True,
attachForm=[
(self.btnAddAdv1, "left", 0),
(self.btnAddAdv1, "top", 0),
(self.btnRemAdv1, "top", 0),
(self.btnClrAdv1, "top", 0),
(self.btnClrAdv1, "right", 5),
attachControl=[
(self.btnRemAdv1, "left", 2, self.btnAddAdv1),
(self.btnClrAdv1, "left", 2, self.btnRemAdv1),
pm.formLayout(
self.formBtns2, edit=True,
attachForm=[
(self.btnAddAdv2, "left", 3),
(self.btnAddAdv2, "top", 0),
(self.btnRemAdv2, "top", 0),
(self.btnClrAdv2, "top", 0),
(self.btnClrAdv2, "right", 0),
attachControl=[
(self.btnRemAdv2, "left", 2, self.btnAddAdv2),
(self.btnClrAdv2, "left", 2, self.btnRemAdv2),
# Main buttons
self.btnRun = pm.button(
command=lambda *args: self.createMap(),
label="Ok",
parent=self.formMain,
self.btnClose = pm.button(
command=lambda *args: self.closeUI(),
label="Close",
# Layout frames
pm.formLayout(
self.formFrames, edit=True,
attachForm=[
(self.frameOptions, "top", 0),
(self.frameOptions, "left", 0),
(self.frameOptions, "right", 0),
(self.frameObjects1, "left", 0),
(self.frameObjects1, "right", 0),
(self.frameObjects2, "left", 0),
(self.frameObjects2, "right", 0),
attachControl=[
(self.frameObjects1, "top", 10, self.frameOptions),
(self.frameObjects2, "top", 10, self.frameObjects1),
attachNone=[
(self.frameObjects1, "bottom"),
(self.frameObjects2, "bottom"),
# Layout main form
pm.formLayout(
self.formMain, edit=True,
attachForm=[
(self.btnRun, "left", 5),
(self.btnRun, "bottom", 5),
(self.btnClose, "bottom", 5),
(self.btnClose, "right", 5),
attachPosition=[
(self.btnRun, "right", 3, 50),
(self.btnClose, "left", 2, 50),
attachNone=[
(self.btnRun, "top"),
(self.btnClose, "top"),
# Display the window
pm.showWindow( window )
## Update UI controls - WARN: NEEDS UPDATE
def updateUI(self, mode):
# Update methods
if mode == -1:
# Simple mode
if self.radGrpOptions.getSelect() == 1:
self.frameObjects1.setVisible(True)
self.frameObjects1.setLabelVisible(True)
self.frameObjects2.setVisible(False)
self.frameObjects2.setLabelVisible(False)
else: # Advanced mode
self.frameObjects1.setVisible(False)
self.frameObjects1.setLabelVisible(False)
self.frameObjects2.setVisible(True)
self.frameObjects2.setLabelVisible(True)
# Update X slider
elif mode == 0:
# Query the slider, round to power of two
optVarVal = pm.intSliderGrp( self.mapSizeX, query=True, value=True )
optVarVal = self.powerOfTwo(optVarVal)
# Edit slider and update the optionVar
pm.intSliderGrp( self.mapSizeX, edit=True, value=optVarVal )
pm.optionVar( intValue=("TestWinoptVarX", optVarVal) )
# Update Y slider
elif mode == 1:
optVarVal = pm.intSliderGrp( self.mapSizeY, query=True, value=True )
pm.intSliderGrp( self.mapSizeY, edit=True, value=optVarVal )
pm.optionVar( intValue=("TestWinoptVarY", optVarVal) )
# Update output path
elif mode == 2:
# Query the field
filePath = pm.textFieldButtonGrp( self.outPath, query=True, text=True )
# Update the optVar
pm.optionVar( stringValue=("TestWinoptVarPath", filePath) )
# Update the padding slider
elif mode == 3:
# Query the slider
paddingVal = pm.intSliderGrp( self.padding, query=True, value=True )
pm.intSliderGrp( self.padding, edit=True, value=paddingVal )
pm.optionVar( intValue=("TestWinoptVarPadding", paddingVal) )
# Update file format optionVar
elif mode == 4:
# Query the list
fileFormat = pm.optionMenuGrp( self.fileFormat, query=True, select=True )
# Update optionVar
pm.optionVar( intValue=("TestWinoptVarFormat", fileFormat ) )
# Else something is wrong
else:
print("You are using updateUI() incorrectly!!!")
# Execute everything
TestWin()
Posted this on CGTalk - got no replies. I guess I’ll have to ask the elite
Clicking the radio buttons switches the visibility of two frames on/off. But for some reason, the first frame still takes up space (10 px in height) despite setVisible(False).
I tried hiding the label as well with setLabelVisible() but that didn’t change a thing. I’ve also tried setting the marginHeight to 0 but that only affects the elements inside the frame.
Why am I getting extra padding like this?
