Hey all.
Apologies if this has already been asked, but is there a way to dynamically alter the items in an optionMenu? I need it to update based on the selection i make on a textScrollList.
VijayL.
Hey all.
VijayL.
Here’s a fun (rough, unoptimized, and kinda sloppy) pattern you could mess around with to get some ideas from, it’s pretty straightforward, there are probably better ways to do it:
import pymel.core as pm
class ChangeMenuOnSelect(object):
WINDOW_NAME = 'changeOnSelectWindow'
menu_data = {'listItem1':['item1a','item1b','item1c'],
'listItem2':['item2a','item2b','item2c'],
'listItem3':['item3a','item3b','item3c']}
def __init__(self):
try:
pm.deleteUI(self.WINDOW_NAME)
except:
pass
finally:
self.layout()
def layout(self):
with pm.window(self.WINDOW_NAME, resizeToFitChildren=True):
with pm.rowLayout(nc=2,rat=(1,'top',0)):
with pm.optionMenuGrp() as self.main_menu:
labels = self.menu_data.get('listItem1')
labels.sort()
for k in labels:
pm.menuItem(l=k)
self.option_menu = self.main_menu.menu()
self.main_list = pm.textScrollList(allowMultiSelection=False, selectCommand=pm.Callback(self._on_list_select))
list_items = self.menu_data.keys()
list_items.sort()
for l in list_items:
self.main_list.append(l)
def _on_list_select(self, *args):
list_contents = self.menu_data.get(self.main_list.getSelectItem()[0])
list_contents.sort()
self.option_menu.clear()
pm.setParent(self.option_menu, menu=True)
for l in list_contents:
pm.menuItem(label=l)
