So here is the thing. I am trying to set up a value of undefined,
Just a simple test with materials.
I run the following code
import MaxPlus
selection = MaxPlus.SelectionManager.Nodes
for i in selection:
g = i.Material
print g
if the object has a material will print
Animatable(VRayMtl)
if the object doesn´t have a material will print None
but if I try to run the following code (when the object has a material).
I will run in the following error
import MaxPlus
for i in selection:
i.Material = None
>> MAXScript MacroScript Error Exception:
– Runtime error: Line 6487 SetMaterial()
<type ‘exceptions.ValueError’> invalid null reference in method ‘INode_SetMaterial’, argument 2 of type ‘Autodesk::Max::Mtl’ <<
So the question is how come the value of the material is None when it doesn’t have the material assigned, but if i try to assign this value directly I get an error. what am I missing? any help here will be appreciated.
