Hey all,
I’m having a weird problem where I can run a mayabatch command that executes python code from the command line fine, but if I try and run it using:
subprocess.Popen(blah)
it generates the following error:
Error: file: C:/<BLAH>/maya/2011-x64/scripts/userSetup.mel line 5: DLL load failed: %1 is not a valid Win32 application.
# File "<maya console>", line 1, in <module>
# File "C:\<BLAH>\shazzamAssetDB.py", line 7, in <module>
# import shazObject, os, re, inspect
# File "C:\<BLAH>\shazObject.py", line 3, in <module>
# from PyQt4 import QtGui
# ImportError: DLL load failed: %1 is not a valid Win32 application.
Now I am running in a 64bit environment on 64bit software throughout. Any ideas why when I use subprocess.Popen this happens?
Is there a better way with mayapy to do run batch processes so I don’t have to use mayabatch?
-L
