Printing to the same line again and again?
Hey guys!
I’m wondering if there’s a way to delete text from the command line console that was printed earlier, so that I can print to the same line again and again.
I know that it’s possible with other scripting/programming languages - some people create animated ASCII art like that: http://www.asciimation.co.nz/
I would like to display some script output without spamming dozens of lines.
Cheers!
-Sascha
How about the ‘cls’ dos command?
I think what you are looking for is carriage return if you are interested in getting back to the beginning of the line without starting a new line. Although if your console does not support it you might not be able to use it in Python.
Here is a list of ascii escape codes that might help you out in Python
http://pythonweb.org/projects/webmodules/doc/0.5.3/html_multipage/lib/node48.html
Here is a simple code that demonstrates the concept
import time
for a in range(1000):
    time.sleep(0.4)
    print " "+"\r%s"%a,
i think he’s going more for using a shell to show dynamic text on the same line, instead of printing out a huge log. sphinx, the python documentation generator, has code to do this. i haven’t looked into it myself, but they have a special logger that will show colored progress bars and generation status all through ascii text in a shell. it works on linux and osx, but probably not too well on windows, given it’s lackluster terminal support
hope that helps.
-chad
Ideally what you want an interface like Ncurses, but it is only available for Posix systems. This is an advanced terminal library. I have not written anything using it but I use alot of apps that use Ncurses.
Alternatively you can get Ncurses running under Windows via Cygwin environment.
