hey everyone,
I stumbled on this excellent vertexConstraint scripted plug-in awhile back and am using it for our surface rigs. Collars, shirts etc. The rig itself uses three of these nodes, and we have 40 rigs going around a neck. Sooo, the full surface rig brings maya to its knees if I use the entire mesh. If I duplicate the mesh, delete all accept the faces I need then copy the weighting to the mesh and create the rig on that mesh its way faster. So I’m thinking the plug must slow down when it’s asking for vertex…
Any ideas on how it could be optimized in the code? I have a little plug-in understanding…not much though.
#// Plug Name: vertexConstraint Node 2.0 beta
#// orignal Author: Chad Robert Morgan
#// unfortunately Chad's site with the source code...
#// http://members.aol.com/docmorgan/plugins.htm
#// doesn't exist anymore...
#// converted Chad's c++ code to a Python Plugin, changed a little bit to the original code...
#// Alex V. U. Strarup... http://www.strarup.net ... april 2009
#// 3d@strarup.net
#// DESCRIPTION : this plug is a Node which make it posible to constrain
#// objects to vertices...
#// first select the vertex you want your object constrained to
#// then select your object... and type the command...
#// vertexConstraint;
#// Installation: put this script in the Maya plugin folder...
#// to activate the plugin, type loadPlugin vertexConstraint;
#// or load via Plugin Manager...
#// Conditions : Use at your own risk, No Banana throwing or whatever if it doesn't work...
#// NO RESPONSABILITIES DUE TO MALFUNCTION, JOB LOST, WHATEVER...
#// copy... steal... modify it... do whatever you want...
#// as long you don't call me up early in the morning... :-D
#//-/////////////////////////////////// Start of Code /////////////////////////////////////////
import math, sys
import maya.OpenMaya as OpenMaya
import maya.OpenMayaMPx as OpenMayaMPx
kPluginNodeName = "vertexConstraint"
kPluginCmdName="vertexConstraint"
# The id is a 32bit value used to identify this type of node in the binary file format.
# please don't use this number in any other plugin's...
# but get your own by contacting Autodesk...
# original id was ( 0x000c1 ) however not sure if this was an unique value...
# so added one of the Id's I got from Alias back in 2004...
kPluginNodeId = OpenMaya.MTypeId(0x0010A781) # id nr. 2 from Alias...
# da Node definition...
class vertexConstraintNode(OpenMayaMPx.MPxNode):
inputShape = OpenMaya.MObject()
output = OpenMaya.MObject()
outputX = OpenMaya.MObject()
outputY = OpenMaya.MObject()
outputZ = OpenMaya.MObject()
vertexIndex = OpenMaya.MObject()
constraintParentInverseMatrix = OpenMaya.MObject()
def __init__(self):
OpenMayaMPx.MPxNode.__init__(self)
#da compute function thingie...
def compute(self,daPlug,daData):
if daPlug == vertexConstraintNode.output or daPlug.parent() == vertexConstraintNode.output:
try:
inputData = daData.inputValue(vertexConstraintNode.inputShape)
except:
sys.stderr.write("Oh Mama %s failed to get da MDataHandle inputValue inputShape
") %kPluginNodeName; raise
try:
vertHandle = daData.inputValue(vertexConstraintNode.vertexIndex)
except:
sys.stderr.write("Oh Mama %s failed to get da MDataHandle inputValue vertexIndex
try:
inverseMatrixHandle = daData.inputValue(vertexConstraintNode.constraintParentInverseMatrix)
except:
sys.stderr.write("Oh Mama %s failed to get da MDataHandle inputValue constraintParentInverseMatrix
try:
outputHandle = daData.outputValue(vertexConstraintNode.output)
except:
sys.stderr.write("Oh Mama %s failed to get da MDataHandle outputValue output
nodeFn = OpenMaya.MFnDependencyNode()
mesh = OpenMaya.MObject()
mesh = inputData.asMesh()
index = vertHandle.asInt()
vert = OpenMaya.MFnMesh(mesh)
inverseMatrix = OpenMaya.MMatrix()
inverseMatrix = inverseMatrixHandle.asMatrix()
pos = OpenMaya.MPoint()
try:
vert.getPoint(index, pos, OpenMaya.MSpace.kWorld)
except:
sys.stderr.write("Oh Mama %s Could not get vert position
pos *= inverseMatrix
#set output attrs
posX = outputHandle.child(vertexConstraintNode.outputX)
posX.setDouble(pos.x)
posY = outputHandle.child(vertexConstraintNode.outputY)
posY.setDouble(pos.y)
posZ = outputHandle.child(vertexConstraintNode.outputZ)
posZ.setDouble(pos.z)
daData.setClean(daPlug)
# everything is oki doki... :)
return OpenMaya.MStatus.kSuccess
# spooky...
else:
return OpenMaya.kUnknownParameter
# da creator may he have mercy on us... :-D
# this method exists to give Maya a way to create new objects of this type...
def nodeCreator():
return OpenMayaMPx.asMPxPtr(vertexConstraintNode())
def nodeInitializer():
nAttr = OpenMaya.MFnNumericAttribute()
tAttr = OpenMaya.MFnTypedAttribute()
mAttr = OpenMaya.MFnMatrixAttribute()
cAttr = OpenMaya.MFnCompoundAttribute()
try:
vertexConstraintNode.inputShape = tAttr.create( "inputShape", "inS", OpenMaya.MFnMeshData.kMesh)
tAttr.setStorable(0)
tAttr.setKeyable(0)
except:
sys.stderr.write("Oh Mama failed to create da inputShape attribute
"); raise
try:
vertexConstraintNode.vertexIndex = nAttr.create( "vertex", "vert", OpenMaya.MFnNumericData.kLong)
nAttr.setWritable(1)
nAttr.setStorable(1)
nAttr.setArray(0)
except:
sys.stderr.write("Oh Mama failed to create da vertexIndex attribute
"); raise
try:
vertexConstraintNode.constraintParentInverseMatrix = mAttr.create("constraintParentInverseMatrix", "pim", OpenMaya.MFnMatrixAttribute.kDouble)
mAttr.setStorable(0)
mAttr.setKeyable(0)
except:
sys.stderr.write("Oh Mama failed to create da constraintParentInverseMatrix attribute
"); raise
try:
vertexConstraintNode.outputX = nAttr.create( "outputX", "X", OpenMaya.MFnNumericData.kDouble)
except:
sys.stderr.write("Oh Mama failed to create da outputX attribute
"); raise
try:
vertexConstraintNode.outputY = nAttr.create( "outputY", "Y", OpenMaya.MFnNumericData.kDouble)
except:
sys.stderr.write("Oh Mama failed to create da outputY attribute
"); raise
try:
vertexConstraintNode.outputZ = nAttr.create( "outputZ", "Z", OpenMaya.MFnNumericData.kDouble)
except:
sys.stderr.write("Oh Mama failed to create da outputZ attribute
"); raise
try:
vertexConstraintNode.output = cAttr.create("output", "out")
cAttr.addChild(vertexConstraintNode.outputX)
cAttr.addChild(vertexConstraintNode.outputY)
cAttr.addChild(vertexConstraintNode.outputZ)
cAttr.setStorable(0)
cAttr.setKeyable(0)
cAttr.setArray(0)
except:
sys.stderr.write("Oh Mama failed to create da output attribute
"); raise
try:
vertexConstraintNode.addAttribute(vertexConstraintNode.inputShape)
except:
sys.stderr.write("Oh Mama failed to add da input attributes
"); raise
try:
vertexConstraintNode.addAttribute(vertexConstraintNode.vertexIndex)
except:
"); raise
try:
vertexConstraintNode.addAttribute(vertexConstraintNode.constraintParentInverseMatrix)
except:
"); raise
try:
vertexConstraintNode.addAttribute(vertexConstraintNode.output)
except:
"); raise
try:
vertexConstraintNode.attributeAffects( vertexConstraintNode.inputShape, vertexConstraintNode.output )
except:
sys.stderr.write("Oh Mama failed setting da attributeAffects
"); raise
try:
vertexConstraintNode.attributeAffects( vertexConstraintNode.vertexIndex, vertexConstraintNode.output )
except:
"); raise
try:
vertexConstraintNode.attributeAffects( vertexConstraintNode.constraintParentInverseMatrix, vertexConstraintNode.output )
except:
"); raise
#--------------------------- da end of the nodeInitilizer -----------------------
# start off vertexConstraint command....
# command
class vertexConstraintCmd(OpenMayaMPx.MPxCommand):
def __init__(self):
OpenMayaMPx.MPxCommand.__init__(self)
self.dgMod = OpenMaya.MDGModifier()
def redoIt(self):
try:
self.dgMod.doIt()
print( "vertexConstraint created......
except:
sys.stderr.write( "Error creating vertexConstraint command
" ); raise
def undoIt(self):
try:
self.dgMod.undoIt()
print( "vertexConstraint removed....
except:
sys.stderr.write( "Error removing vertexConstraint command
" ); raise
def doIt(self, args):
slist = OpenMaya.MSelectionList()
OpenMaya.MGlobal.getActiveSelectionList(slist)
component = OpenMaya.MObject()
targetDagPath = OpenMaya.MDagPath()
targetVertexFn = OpenMaya.MFnMesh()
destDagPath = OpenMaya.MDagPath()
destTransformFn = OpenMaya.MFnTransform()
try:
vert = OpenMaya.MItSelectionList(slist, OpenMaya.MFn.kMeshVertComponent)
except:
sys.stderr.write("Oh Mama %s Could not create iterator
") %kPluginCmdName; raise
try:
vert.getDagPath(targetDagPath, component)
except:
sys.stderr.write("Oh Mama %s Could not get dag path to vertex
if(component.isNull()):
sys.stderr.write("Oh Mama no vertexes are selected
"); raise
try:
targetVertexFn.setObject(targetDagPath)
except:
sys.stderr.write("Oh Mama %s Could not set vertes to object
try:
vertIndex = OpenMaya.MItMeshVertex(targetDagPath, component)
except:
sys.stderr.write("Oh Mama %s Could not get the vertIndex
try:
dest = OpenMaya.MItSelectionList(slist, OpenMaya.MFn.kTransform)
except:
try:
dest.getDagPath(destDagPath)
except:
sys.stderr.write("Oh Mama %s Could not get dag path to transform
try:
destTransformFn.setObject(destDagPath)
except:
sys.stderr.write("Oh Mama %s Could not set fn to transform
# create vertexConstraint node
try:
vertexConstraintObj = OpenMaya.MObject(self.dgMod.createNode("vertexConstraint"))
except:
sys.stderr.write("Oh Mama %s Could not create vertexConstraint node
vertexConstraintFn = OpenMaya.MFnDependencyNode(vertexConstraintObj)
inMeshPlug = OpenMaya.MPlug()
inMeshPlug = vertexConstraintFn.findPlug("inputShape")
# get output worldmesh from shape
worldMeshPlug = OpenMaya.MPlug()
worldMeshPlug = targetVertexFn.findPlug("worldMesh")
worldMeshPlug = worldMeshPlug.elementByLogicalIndex(targetDagPath.instanceNumber())
inverseMatrix = OpenMaya.MPlug()
inverseMatrix = destTransformFn.findPlug("parentInverseMatrix")
inverseMatrix = inverseMatrix.elementByLogicalIndex(destDagPath.instanceNumber())
vertexPlug = OpenMaya.MPlug()
vertexPlug = vertexConstraintFn.findPlug("vertex")
vertexPlug.setInt(vertIndex.index())
try:
self.dgMod.connect((vertexConstraintFn.findPlug("output")), (destTransformFn.findPlug("translate")))
except:
sys.stderr.write("Oh Mama %s Could not connect output to translation
try:
self.dgMod.connect(worldMeshPlug, inMeshPlug)
except:
sys.stderr.write("Oh Mama %s Could not connect world mesh to constraint
try:
self.dgMod.connect(inverseMatrix, vertexConstraintFn.findPlug("constraintParentInverseMatrix"))
except:
self.redoIt()
def isUndoable(self):
return True
# command Creator
def cmdCreator():
# Create the command
return OpenMayaMPx.asMPxPtr( vertexConstraintCmd() )
# initialize the script plug-in
def initializePlugin(mobject):
mplugin = OpenMayaMPx.MFnPlugin(mobject, "vertex Constraint Node", "2.0", "Any")
try:
mplugin.registerNode( kPluginNodeName, kPluginNodeId, nodeCreator, nodeInitializer, OpenMayaMPx.MPxNode.kDependNode)
except:
sys.stderr.write( "Failed to register node: %s" % kPluginNodeName ); raise
try:
mplugin.registerCommand( kPluginCmdName, cmdCreator )
except:
sys.stderr.write( "Failed to register command: %s
" % kPluginCmdName ); raise
# uninitialize the script plug-in
def uninitializePlugin(mobject):
mplugin = OpenMayaMPx.MFnPlugin(mobject)
try:
mplugin.deregisterNode( kPluginNodeId )
except:
sys.stderr.write( "Failed to deregister node: %s" % kPluginNodeName ); raise
try:
mplugin.deregisterCommand( kPluginCmdName )
except:
sys.stderr.write( "Failed to unregister command: %s
