Playblast multiple views in maya
Hello, first post here… need some help on creating a small tool.
I was trying to create a tool to playblast all the views in maya for the animators at work.
Here is what am doing so far…
import maya.mel as mel
viewPanels = cmds.getPanel(type="modelPanel")
visiblePanels = cmds.getPanel(visiblePanels=True)
renderPanels = list( set(viewPanels) & set(visiblePanels) )
for panel in renderPanels:
	cmds.setFocus(panel)
	panelName = cmds.panel(panel, q=True, label=True).split(" ")[0]
	print panelName
	renderPath = "~/Desktop/test/playblast/%s.mov"%panelName
	mel.eval('playblast  -format qt -filename "'+renderPath+'" -sequenceTime 0 -clearCache 1 -viewer 1 -showOrnaments 1 -offScreen  -fp 4 -percent 100 -compression "jpeg" -quality 100;')
This works fine if I have a quad view… where all the views will be rendering by their actual names. Side, Front, Top and Persp.
But it fails to recognize the view name if I have two views.
If I have just perspective and side view it renders both the views properly, but the panelName is returned as Top instead of Side.
Am I missing something… please point out if there is any better way of doing it.
Instead of getting the label for the panel, you can get the camera associated with the panel:
cameraName = cmds.modelEditor(panel, q=True, camera=True)
renderPath = "~/Desktop/test/playblast/%s.mov"%cameraName
That solves the problem. Thanks.
Hey I have a quick question for you, why are you using mel.eval for the playblast when you can use cmds.playblast as well?
Does this change something? I’m currently trying to write a tool using playblast and I’m having some trouble.
