Perforce image diff
Anyone know where/how to adjust the file type settings so a Maya ASCII file is treated as text, by p4merge? It’s currently diffing them as images, which… is less useful. Though impressive!
For a single file:
If you’re using P4v, check the file out, right-click it and hit “Change file type”, then change the “base file type” setting. You’ll have to submit the file for it to stick.
For all files of a certain extension added in the future:
Use the typemap command.
Thank you!
