I have a function in python that sets a bunch of vertex normals. However if i wrap this in a undoInfo chunk and close it, only the cmds stuff gets undone, the vertex normals are untouched by the undo.
Is there a separate path I need to take when using OpenMaya commands?
I think you’ll have to write it as a command plugin so that the API methods will undo properly. An SDK example using the correct methods would be “C:\Program Files\Autodesk\Maya2012\devkit\plug-ins\scripted\blindDoubleDataCmd.py”. Looks like you have to implement the redoIt, undoIt, and isUndoable methods.
