hi there
i wanted x86 version of PyQt compiled against Maya’s Qt 4.5.3
http://nathanhorne.com/?p=229 this link is not opening.
does anybody have this version of pyqt?
thanks in advance
mossin
hi there
thanks in advance
mossin
which version of Maya was that - 2011 I assume??
if it’s 2009/08 then this should work (because that’s what we’re using PyQt-Py2.5-gpl-4.7.7-) never versions might work too:
http://www.riverbankcomputing.co.uk/software/pyqt/download
for 2011/2010 x86 I couldn’t get Nathan’s version working properly. But I should have another compiled version somewhere… I’ll see if I still have it and if I can upload it somewhere)
For x64, those work:
http://dl.sebr.fr/download/packages/PyQt-Py2.5-gpl-4.5.4-1_amd64.exe (2008/2009)
And again Nathan’s used to work for x64 2011/2010. I think I have those somewhere too
hi RobertKist
thanks for your reply
2011 x86 please
Sorry about my links being down, I’m changing my hosting right now
Here’s links for my compiled versions:
PyQt 4.7.3 x64
PyQt 4.7.3 x86
Edit: If it gives you an import error for the x86 version here’s an alternate version to try (this one doesnt include an installer, it’s just the raw files) - Link
http://www.robertkist.com/stuff/PyQt-Py2.6-gpl-4.6.2-1.exe
We’ve got this one working here for 2011 and 2010 x86. It’s a different PyQT version but the Qt libraries should be the same version as in Nathan’s build.
P.S. and don’t worry about the SQL modules - I couldn’t get them to work in Maya with any Qt version…just in case db access is something you need. But I can totally recommend pyODBC for this. works with all maya versions
thanks robert and nathan !!!
i will try and let you know
thanks both of you
@ robert, for some reason i couldnt install pyqt from your link, i m getting this error
“installer integrity has failed. causes include incomplete download and damaged media”
@ nathan, i downloaded your raw file link, and i got all necessary files, i have’nt checked them yet, but hoping those are wroking
anyway thanks a lot for quick support from both of you !!!
regards
mossin
doh. I had to resume the upload a few time becaue of the internet here in China. I guess that broke it I’ll try again uploading later today…unless you get Nathan’s verison to work.
hey robert
thanks for your response, i will let you know
cheers
mossin
hi all
@ Nathan
i tried this on 32 bit of maya 2011, and it is working just fine !!!
thanks for sharing
regards
mossin
