hello everyone…
there’s a problem while i am using Maya muscles creator for creating muscles.when i sculpt the muscles using point selection in cross section curves Maya undo stops working.below are the process i am following:
after setting the desired rest,squash and stretch poses when i sculpt the muscles using point undo works for first time but when i switch to edit other curves and sculpt it using point selection Maya undo stops working.every times error comes as(//Error:line1:there are no more commands to undo)and i am not able to use undo command until i restart Maya .please let me know the solution for this i have tried it in Maya 2009 as well as in higher versions but still facing the same problem.
