Multiple Master Controls in Rig
I’m trying to add two master control to my rig , here is image that wat i’m trying to do
First i connected global translate group, global scale group to global ctrl by using connection Editor and then i parent the global ctrl to master ctrl.
When i move or rotate the global ctrl it’s working perfect, but if i move master ctrl nothing happening. I do no wat i’m missing.
When you say you connected them, do you mean you connected translate or rotate attributes? If you want the controls to follow the master you’ll have to parent them or use constraints.
@Theodox Thanks you, i found the solution.
