A bunch of our modelers have moved over to Modo, so we’ve started supporting them with tools.
We use Python. We ended up writing a ton of modules for interacting with the built-in macro system in a way that feels object-oriented even though under the hood Modo’s scene organization is completely different. It wasn’t a small undertaking by any means. We use approximately one python command out of the lx module: eval. You pretty much just have to learn the command macros and do a lot of string processing
The first advice I have is to make sure you understand how object queries can influence subsequent macro commands. In many cases, querying a basic property of an object puts it in focus, or selects it, or however you’d like to think of it. Subsequent commands rely on that previous “selection” in order to know which object to reference when executing. For example, if I want to find out information about a channel on an object “mesh013”, I’d first “select” the object like so (in python):
lx.eval( "!query sceneservice item.ID ? mesh013" )
I’m not even bothering to store the item’s ID. Actually I already know it – it’s mesh013. So this would be a silly and pointless query if it weren’t necessary to “select” this object. In this case I could be querying anything about mesh013, name, id, whatever. I have to do this only because there is no explicit way to specify an object in the next query, where I find out the first channel’s name:
channelName = lx.eval( "!query sceneservice channel.name ? 0" )
I’ve also gotten into the habit of indiscriminate use of the exclamation point, as you can see above. It suppresses dialogs including error dialogs for the specific command you just ran. Double exclamation points suppress all dialogs, so if the command you ran has sub-commands, all their dialogs are also suppressed.
What else? Well, in the current version of Modo, each time you run a python script a new instance of python is opened, and it shuts down when script execution ends. This has a couple of effects. Obviously, there’s no scripted variable persistence. You can store data if necessary in user values. Less obvious: if you’re attaching a debugger you need to make sure it isn’t set up to expect a persistent connection.
We spent a ton of time just testing and running through individual commands. Not everything works the way you’d expect, and some things are actually not fully functional. So as you test, be aware that you need to test not just your code but the commands themselves to make sure you’re getting what you expect. The documentation isn’t fully accurate in all cases and there are still bugs because honestly the command system is not well exercised by the vast majority of Modo users. Modo scripters are a very very small community. But if we grow things can only improve, so it’s cool that you’re interested.
That’s the best advice I’ve got. Let me know if you have specific questions. Having been through setting up the foundation for our Python tools in Modo as well as having written some end-user-facing scripts, I know all sorts of interesting things.
