I’m trying to run some mel commands to load fbx presets and export a fbx from maya. I’m doing the work in a python script so that it can be batched by using mayapy. However, every time I run the script, it stops at the mel FBX command, stating that it cannot find the procedure. The error happens on all the mel FBX commands.
import maya.standalone as std
import maya.mel as mel
std.initialize(name='python')
exportFile = "C:/maya/fileToExport.ma"
cmds.file(exportFile,o=1,f=1)
fbxPresetPath = "E:/fbxpresets/TEST.fbxexportpreset"
fbxCommand = "FBXLoadExportPresetFile -f \"" + fbxPresetPath + "\""
mel.eval(fbxCommand)
In the command line I cycle to Maya’s bin drive and run: mayapy scriptToRun.py
I’m I just missing something stupid? It seems like it should work since it works on other mel commands, except FBX ones.
Thanks!
