Hello there,
Is there a maya grunt scripter here, who can solve this :
Pb= set maya to 25fps even if someone delete locally the maya prefs
Info = all maya are pointing to a server via maya.env.
I tried to :
A) code in userSetup.py (set the values directly)
import maya.cmds as mc
mc.currentUnit(t=“pal”)
print mc.currentUnit(q=True,t=True)
the output window print “pal” but it isn’t in maya (still 24fps)
B) code in userSetup.py (copy a file from serv to local)
import shutil
src=“PathOnServ\userPrefs.mel”
trg=“PathLocal\prefs”
shutil.copy(src,trg)
but maya overwrite the file with the default one (I tested my code with a .py and it works)
Any idea ?
