Maya selection question
Hello,
Straight to the point, I am trying to figure out the easiest way to select all locators in a scene besides doing it manually or storing the names in a list(unless the list is my only option). I dont know if I am just over looking a command or what but I have yet to come across something. Thank you for any and all help.
//MEL
pickWalk("-d","up",ls("-typ","locator"))
#cmds
maya.cmds.pickWalk(maya.cmds.ls(type="locator"),d="up")
Awesome, thanks Seth, much appreciated!
What was the problem with making a list?
cmds.select(cmds.ls(type=‘spaceLocator’), replace=True)
select -r ls -type "spaceLocator";
I wanted something a little more dynamic which you have both helped me with, I did not know you could nest commands inside the select command. Thank you so much!
[QUOTE=cdmcg;10388]I wanted something a little more dynamic which you have both helped me with, I did not know you could nest commands inside the select command. Thank you so much![/QUOTE]
You can pass returns between MEL commands like you could with most other languages:
select `ls -typ joint`;
//or
select(ls("-typ","joint"));
using the backticks limits your depth, that is:
//this is legal
select(pickWalk("-d","up",ls("-typ","locator")));
//this isn't
select `pickWalk -d up `ls -sl -typ locator``;
but that’s probably not a bad thing
Nope, but using MEL over python is! :stuck_out_tongue:
[QUOTE=dbsmith;10399]Nope, but using MEL over python is! :p[/QUOTE]
This.
