Maya <=> pycharm IDE (support to get maya track back and error line)
send selected lines to maya
save following script as “send_to_maya.py”
pycharm external parameters setting >
[your path\send_to_maya.py] $FilePath$ $SelectionStartLine$ $SelectionEndLine$
#PyCharm python script by Yann Schmidt, https://github.com/justinfx/MayaSublime; Edited by Dontnoun(for trace back, error line number)
#Version: 1.0       Send whole file to Maya via commandPort and get trackback to pycharm (track back does not work for multi-process-thread function)
#copy below 5 lines to your ..\Users\[user name]\Documents\maya\[maya_version]\scripts\userSetup.py(remove first '#' symbol for each line)
#import maya.cmds as cmds
#try : cmds.commandPort(n='127.0.0.1:7001' , bs=128000, stp = 'mel')
#except : pass
#try : cmds.commandPort(n='127.0.0.1:7002' , bs=128000, stp = 'python')
#except : pass
import sys, os, textwrap, time
from telnetlib import Telnet
class SendToMaya(object):
    PY_CMD_TEMPLATE = textwrap.dedent('''
        import traceback
        import __main__
        namespace = __main__.__dict__.get('_pycharm_SendToMaya_command')
        if not namespace:
            namespace = __main__.__dict__.copy()
            __main__.__dict__['_pycharm_SendToMaya_command'] = namespace
        namespace['__file__'] = {2!r}
        try : {0}({1!r}, namespace, namespace)
        except : traceback.print_exc()    ''')
    def __init__(self):
        self.maya_log_pth = os.path.dirname(os.path.abspath(__file__)).replace('\\','/') + '/'
        self.execType = 'execfile'
        self.fileType = 'python'
        slins_buf_py_pth = self.maya_log_pth + 'slins_buff.py'
        with open(str(sys.argv[1]), 'r') as slin_id :
            slines = slin_id.readlines()[ int(sys.argv[2])-1: int(sys.argv[3]) ]
        with open(slins_buf_py_pth, 'w+') as wslns_id :
            for ww in slines : wslns_id.write(ww)
        self.file = slins_buf_py_pth        #str(sys.argv[1])
        self.sep = None
        self.is_python()
        self._settings = dict()
        self.init_settings()
    def init_settings(self):
        maya_hostname = "127.0.0.1"     #-------------!!!
        python_command_port = 7002      #-------------!!!
        mel_command_port = 7001         #-------------!!!
        self._settings['host'] = maya_hostname
        if self.fileType == 'python':
            self._settings['port'] = python_command_port
            self.sep = '
        else:
            self._settings['port'] = mel_command_port
            self.sep = '\r'
    def is_python(self):
        if sys.argv[1].endswith('.py'):     self.fileType = 'python'
        elif sys.argv[1].endswith('.mel'):  self.fileType = 'mel'
        else:                               self.fileType = None
    def run(self):
        maya_log_pth = self.maya_log_pth + 'pycharmya.log'
        with open(maya_log_pth, 'w+') as empty_id : empty_id.write('')
        buff_pym_pth = self.maya_log_pth + 'maya_2pycharm_buf.fer'
        if self.fileType is None:
            print("No Maya-Recognized language found.")
            return
        #----------------------#----------------------VVV   to get maya track back and debug line
        crnt_py_line_lst = []
        with open(self.file, 'r')  as crnt_fid :
            for cc in  crnt_fid.readlines() :
                crnt_py_line_lst.append(cc.strip('
        if self.fileType == 'python' :
            pre_cmd = "import maya.cmds as cmds; mlg = '" + self.maya_log_pth + "pycharmya.log'; cmds.scriptEditorInfo(hfn = mlg, wh=1);print 'MaYa Track Back :\
            pst_cmd = "import maya.cmds as cmds; cmds.scriptEditorInfo(hfn = mlg, wh=0)"
            mrk_cmd = "with open('" + self.maya_log_pth + "maya_2pycharm_buf.fer', 'w+')  as bfd : bfd.write('xxx')"
            with open(buff_pym_pth, 'w+')  as buff_fid :
                buff_fid.write(pre_cmd + '
                buff_fid.write('import sys, traceback
try :
                for bb in crnt_py_line_lst :   buff_fid.write('    ' + bb + '
                buff_fid.write('except Exception as eRr :
    for x in traceback.extract_tb(sys.exc_info()[2]):print type(eRr), eRr.args[0], "\
", "Error on line:", x[1]-3, "--> ", x[3], "\
                buff_fid.write(pst_cmd + '
' + mrk_cmd + '
        else : buff_pym_pth = self.file     #-----for mel
        #----------------------#----------------------AAA   to get maya track back and debug line
        snips = []
        if self.fileType == 'python':       snips.append(buff_pym_pth)
        else:                               snips.append('rehash; source "{0}";'.format(buff_pym_pth))
        mCmd = str(self.sep.join(snips))
        if not mCmd :                       return
        if self.fileType == 'python':       mCmd = self.PY_CMD_TEMPLATE.format(self.execType, mCmd, buff_pym_pth)
        if self.fileType == 'mel':          mCmd = mCmd.replace('\\', '/')
        tnt = None
        try:
            tnt = Telnet(   self._settings.get('host'),    int(self._settings.get('port')),     timeout=3   )
            tnt.write(mCmd.encode(encoding='UTF-8'))
            if self.fileType == 'python' :  self.get_maya_trackback()      #-------------!!! track back only for python not mel
        except Exception:
            err = str( sys.exc_info()[1] )
            print("Failed to communicate with Maya (%(host)s:%(port)s)):
%(err)s" % locals())
            raise
        else: time.sleep(.1)
        finally:
            if tnt is not None: tnt.close()
    def get_maya_trackback(self):
        while 1 :
            time.sleep(0.3)             #-------------!!!
            with open(buff_pym_pth, 'r') as buf_id :
                mrk_str = buf_id.readline().strip('
            with open(maya_log_pth, 'r') as crash_id :
                crash_str = crash_id.readline().strip('
            if crash_str is not None and crash_str != 'MaYa Track Back :' :
                print 'Fatal SyntaxError: Can not run in MaYa!'
                break
            if mrk_str == 'xxx':        #-------------!!!
                with open(maya_log_pth,'r') as mlog_id :
                    for ii in mlog_id.readlines():
                        print ii.strip('
                break
snd = SendToMaya()
snd.run()
#-----------------------------------------------old version
when I move maya python IDE to Pycharm, got a problem, pycharm can not get track back and error info from maya,
searched in google ,found something :
http://tech-artists.org/forum/showth...5280-MayaCharm
unfortunately it does not work for my computer…
maybe difference maya, pycharm version or os platform caused problem
then found a script from this page,
http://www.yannschmidt.com/blog/crea...mmand-pycharm/
its pretty good, I edited the script to get maya track back and error line info
it is a simple python script, should work in many versions of maya and pycharm and os
edited script is here:
Code:
#PyCharm python script by Yann Schmidt, GitHub - justinfx/MayaSublime: Send selected Python and MEL code snippets from SublimeText to Maya via commandPort; Edited by Dontnoun(for track back, error line number)
#copy below 5 lines to your …\Users[user name]\Documents\maya[maya_version]\scripts\userSetup.py(remove first ‘#’ symbol for each line)
#try : cmds.commandPort(n=‘127.0.0.1:7001’ , bs=128000, stp = ‘mel’)
#except : pass
#try : cmds.commandPort(n=‘127.0.0.1:7002’ , bs=128000, stp = ‘python’)
#except : pass
PY_CMD_TEMPLATE = textwrap.dedent(‘’’
import traceback
import main
namespace = main.dict.get(‘_pycharm_SendToMaya_command’)
if not namespace:
namespace = main.dict.copy()
main.dict[‘_pycharm_SendToMaya_command’] = namespace
namespace[‘file’] = {2!r}
except : traceback.print_exc() ‘’')
def __init__(self):
    self.file = str(sys.argv[1])
    self.sep = None
    self.is_python()
        self.sep = '
else:
self._settings[‘port’] = mel_command_port
self.sep = ‘\r’
def run(self):
        return
pst_cmd = “import maya.cmds as cmds; cmds.scriptEditorInfo(hfn = mlg, wh=0)”
mrk_cmd = "with open(’" + self.maya_log_pth + “maya_2pycharm_buf.fer’, ‘w+’) as bfd : bfd.write(‘xxx’)”
with open(buff_pym_pth, ‘w+’) as buff_fid :
buff_fid.write(pre_cmd + ’
try :
for bb in crnt_py_line_lst : buff_fid.write(’ ’ + bb + ’
", “Error on line:”, x[1]-3, "–> ", x[3], "
buff_fid.write(pst_cmd + ’
’ + mrk_cmd + ’
    snips = []
    tnt = None
    try:
    except Exception:
raise
finally:
if tnt is not None:
tnt.close()
    while 1 :
        time.sleep(0.2)             #-------------!!!
with open(maya_log_pth, ‘r’) as crash_id :
crash_str = crash_id.readline().strip(’
if crash_str is not None and crash_str != ‘MaYa Track Back :’ :
print ‘Fatal SyntaxError: Can not run in MaYa!’
break
if mrk_str == ‘xxx’: #-------------!!!
with open(maya_log_pth,‘r’) as mlog_id :
print ii.strip(’
break
snd = SendToMaya()
snd.run()
