Maya .net Api Question
Hey all,
Been a long time since I’ve been on due to work and general stuff, glad to be back.
I was just trying out the .Net api for Maya and I was wondering if anyone could help me out.
I am converting an old python plugin to .net just to compare the two and I am having a problem with setting the type of the input parameter.
In Python I did this:
tAttr = OpenMaya.MFnTypedAttribute ()
SpiralCurveNode.inputCurve = tAttr.create( "inputCurve", "ic", OpenMaya.MFnData.kNurbsCurve)
In the .net api they do this:
[MPxNodeNumeric("in", "input", MFnNumericData.Type.kFloat, Storable = false, Writable = false)]
public static MObject input = null;
I can’t seem to see how to change it the type to a nurbs curve. I’m guessing its something pretty simple that I’m just overlooking.
Can anyone offer any guidance?
Cheers.
MPxNodeNumeric is a shortcut attribute that simplifies adding numeric attributes without the need of having a node initializer method. You’ll need to implement the initialize method and create the attributes just like you would in C++/Python.
class Node : ...
   public static MObject inputCurve = null;
   [MPxNodeInitializer()]
   public static bool initialize()
      // Create the attribute like normal
Cheers, I wasn’t sure if there was a shorthand way to do it via attributes like with numeric ones,
