Hi everyone!
I generally program Unity3D related stuff, I’m still pretty new to Maya’s python API.
What I’m trying to do is to get the currently selected face normals average:
What I need to achieve
What I achieved until now is an instance of a cube positioned according to the Move Manipulator.
import re #regular expression
# get current position of the move manipulator
pos = cmds.manipMoveContext('Move', q=True, p=True)
# get the current selection
selection = cmds.ls(sl=True)
# trying to get the face normal angles of the current selection
polyInfo = cmds.polyInfo(selection, fn=True)
polyInfoArray = re.findall(r"[\w.-]+", polyInfo[0]) # convert the string to array with regular expression
polyInfoX = float(polyInfoArray[2])
polyInfoY = float(polyInfoArray[3])
polyInfoZ = float(polyInfoArray[4])
print str(polyInfoX) + ', ' + str(polyInfoY) + ', ' + str(polyInfoZ)
target = cmds.polyCube()
cmds.move(pos[0], pos[1], pos[2], target)
Now what I only need is to rotate the cube to the face average normals of the selection
Please, any thoughts about this?
Maya does have any method to give me those angles? I tried to rotate using polyInfo with face normals, but I think I’m missing something…
polyInfo will give you the normal, but it will be formatted as a string, so you need to extract the values out and convert to something usable, like a tuple.
cmds.polyInfo(polygonFace, faceNormals=True)
Thanks for the response @rgkovach123
I already did this in that part of my the code:
But isn’t the exact value that I need for rotation:
cmds.rotate(polyInfoX, polyInfoY, polyInfoZ, target)
Maybe I’m missing a conversion or something…
Any thoughts?
I found a workaround, if anyone is interested in the answer, here is what I did for the final solution:
pos = cmds.manipMoveContext('Move', query=True, position=True)
selection = cmds.ls(selection=True)
# target = cmds.polyCube()
target = cmds.group(world=True, empty=True, name=('Point'))
constr = cmds.normalConstraint(selection, target, aimVector = (0,0,1), worldUpType= 0)
cmds.delete(constr)
yea, the normal of the face can be twisted around any amount, so some additional information is required in the form of the up vector.
