So I was trying to find the best way to get the names of every parent of an object (so if you had a object parented under a group the group could be further nested under others).
Off the top of my head, two ideas I have would be:
use listRelative to find the parent, and then recursion to continue up the chain of parents saving each to a list
get the ‘fullPath’ or ‘long’ name of the current object with say the ls command and parse the string for the names
What do you think is the best method or do you have another even better method?
parents = cmds.ls(node, long=True)[0].split('|')[1:-1]
# This is depending on the order you want the parents in
parents.reverse()
Or if you’re using pymel, node.getAllParents()
The only time I’d use listRelatives recursively is if you wanted to account for instancing and trace multiple parent paths. But even then maybe this would list the full path to all parents
cmds.listRelatives(node, allParents=True, fullPath=True) [?].
If you’ve not messed with the list of parents yet, you can turn it back into long names pretty easily. You just do a join on the parents instead of splitting.
Which would let you avoid having to do recursive listRelative calls.
parents = cmds.ls(node, long=True)[0].split(’|’)[1:-1]
parents_long_named = [’|’.join(parents[:i]) for i in xrange(1, 1 + len(parents))]
[QUOTE=R.White;25498]If you’ve not messed with the list of parents yet, you can turn it back into long names pretty easily. You just do a join on the parents instead of splitting.
parents_long_named = [’|’.join(parents[:i]) for i in xrange(1, 1 + len(parents))][/QUOTE]
Very cool, thanks. When I have a chance maybe I’ll try it that way. I had already gone ahead and made a recursive function. Seems to be working pretty well, thus far.
