Maya expression : Get return value from python procedure
Hello,
this code works fine :
python
def def_test():
    print "hello"
expression
python "def_test()";
But I cannot return a value from python to expression :
python
def def_test():
    return 1.33
expression
float $val = python "def_test()";
Do you have any ideas ?
Thanks, Arthur
You forgot the little single backwards quotes:
http://download.autodesk.com/us/maya/2010help/index.html?url=Using_Python_in_Maya_Communicating_between_Python_and_MEL.htm,topicNumber=d0e42436
Thanks a lot
it was that easy :nod:
