I’m trying to figure out how deformerWeights() works with multiple shapes and one deformer.
Eg: I have ffd1 applied on pCone1 and pCube1. I’m exporting and imoprting the painted weights with:
import os
import maya.cmds as mc
home_dir = os.environ["HOME"]
path= os.path.join(home_dir, "weights")
if not os.path.exists(path):
os.makedirs(path)
# Export
mc.deformerWeights("weights.json", export=True, deformer="ffd1", fm="JSON", path=path, shape=['pCubeShape1', 'pConeShape1'])
# import
mc.deformerWeights("weights.json", im=True, deformer="ffd1", fm="JSON", path=path)
The data in json file is correct but I get Maya crash when import it. So what is the way guys you use to handle this?
Or maybe I should just write my own import/exporter?
I don’t have a solution. I just know that deformerWeights() was messed up for me too in Maya 2018. I was attempting to use it for deltaMush, and I seem to remember it was either crashing, mangling the weights, or both.
I ended up writing a pretty awful script that set the deltaMush.weightList[idx] manually for each vertex. Unfortunately, the only comment I left myself at the time was:
# deformerWeights is busted... Set the weights manually......
Were you able to run this correctly when there is an FFD on only one single shape?
Thanks Chris for your reply.
Yes, with one shape it works but in my case and I think for everyone who do rigs it’s useless. I don’t understand why it writes data and then can’t apply it. It is quite frustrating
At least now I know that I need to write my own tool.
