Hi everyone,
I have asked the following question in a couple of places and I have yet to receive a reply, hopefully someone here will be able to assist me.
My question is related to the process of creating a custom rigid body node to work within Maya. I want to practice and develop my physics programming skills so I decided to take on this task and for obvious reasons I want to do within Maya. I have experience with the C++ API but not so much with the Python one other than internal UI things, therefore I decided to use Python to tackle this task as I believe it will be faster to create some sort of a prototype.
Would anyone with any insight in this area be able to give me a breakdown of how to approach this task?
More specifically:
What kind of node would a rigid body need to be? I am aware that you can have a deformer node for example, will a rigid body be based on that on something else?
I noticed that Maya uses the concept of fields for adding physics such as gravity etc, do I need to develop a custom field somehow to work along the rigid body node?
Any examples out there that I can have a look and gain some more knowledge from?
How do I go about testing physics code within Maya?
For example my primary goal would be something as simple as to have a sphere, or a mesh be affected by gravity then add collision and more attributes like friction, velocity etc.
Just to clarify, I am mostly after on how to tackle this in terms of Maya and not the actual physics code.
Thanks for all your help and time in advance and I wish you all Happy Christmas!
Mortal2God
