I am trying to make a material plugin via the scripted plugin system in MAX.
I have been able to create the basic functionality I need using the standard structure explained in the documentation. However, I want to dynamically add content described in the following example with a for loop, either by creating the rollout with an execute function or via the rolloutcreator tool.
plugin material EasyDecal
classID:#(695425,446581)
extends:Standard replaceUI:true version:1
--Place no#1
parameters main rollout:params
MBdiff type:#texturemap ui:MBdiff
--Place no#2
rollout params "Decal Parameters"
mapbutton MBdiff pos:[16,16] width:212
The problem seems to be that you cannot use execute or the rolloutcreator at either location described above.
Here is some examples of some things I have tried:
Place no#1
str = "(
rollout params \"Decal Parameters\"
mapbutton MBdiff
execute str
Place no#2
paramsRCI = rolloutCreator "params" "Decal Parameters"
paramsrci.begin()
paramsRCI.addControl #button #BtnSourceFolder "Show Maps Folder: " paramStr:"align:#left"
paramsRCI.end()
str = "rollout params \"Decal Parameters\" (
edittext MapFolderLocation)"
(execute str)
I figure this could just be an issue of scope but I doubt it. I’m guessing that if there is a work around it will be something that isn’t apparent.
