[MaxScript] Particle Script - no syntax highlight
Hello mates
I’m when I add a Birth Script or Script Operator in Particle Flow and push the Edit Script button the script is opened in another window then the Script Editor (without any tabs) and there is no syntax highlight, all the text is in light grey - why is this? And also the script is save to the harddrive without any file extension, just name, e.g. “Birth Script 01” so the script editor (as well as windows) does not recognize the file. The script works though, I can evaluate it just fine. But it is annoying to write without syntax colouring.
Any suggestion? Cheers mates!
