[MAXScript] Dynamic Parenting and Animatable Pivot Scripts
Hello,
I’ve recently started using the maxObjectTab parameter array after reading about it and its benefits on Paul Neale’s website. Here a few quick scripts I wrote which I thought I’d share
Dynamic Parenting:
	delete objects
	redBox = Box name:"Red Box" position:[-30,0,0] wireColor:red length:20 width:20 height:20
	greenBox = Box name:"Green Box" position:[0,0,0] wireColor:green length:20 width:20 height:20
	blueBox = Box name:"Blue Box" position:[30,0,0] wireColor:blue length:20 width:20 height:20
	parentPt = Point name:"Parent Point" position:[0,0,0] centerMarker:false axisTripod:false cross:false box:false size:0
	childBox = Box name:"Child Box" position:[0,30,0] wireColor:yellow length:10 width:10 height:10
	childBox.parent = parentPt
	posCon = Position_Constraint()
	posCon.appendTarget redBox 0
	posCon.appendTarget greenBox 0
	posCon.appendTarget blueBox 0
	parentPt.position.controller = posCon
	rotCon = Orientation_Constraint()
	rotCon.appendTarget redBox 0
	rotCon.appendTarget greenBox 0
	rotCon.appendTarget blueBox 0
	parentPt.rotation.controller = rotCon
	ca = attributes myParentTest
		parameters myParentP rollout:myParentR
			listItem type:#integer ui:parentList default:1
			objectTab type:#maxObjectTab tabSizeVariable:on tabSize:0
		rollout myParentR "Parent Switching"
			dropDownList parentList "Parent List:" items:#("World", "Red", "Green", "Blue")
			on parentList selected item do
				childRot = objectTab[2].node.rotation
				childPos = objectTab[2].node.position
				disableSceneRedraw()
				with animate on
					sliderTime += -1
					case of
						(objectTab[1].node.position.controller.getWeight 1 == 0 and objectTab[1].node.position.controller.getWeight 2 == 0 and objectTab[1].node.position.controller.getWeight 3 == 0):
							objectTab[1].node.position.controller.setWeight 1 0
							objectTab[1].node.position.controller.setWeight 2 0
							objectTab[1].node.position.controller.setWeight 3 0
							objectTab[1].node.rotation.controller.setWeight 1 0
							objectTab[1].node.rotation.controller.setWeight 2 0
							objectTab[1].node.rotation.controller.setWeight 3 0
							objectTab[2].node.rotation = childRot
							objectTab[2].node.position = childPos
						(objectTab[1].node.position.controller.getWeight 1 == 100):
							objectTab[1].node.position.controller.setWeight 1 100
							objectTab[1].node.rotation.controller.setWeight 1 100
						(objectTab[1].node.position.controller.getWeight 2 == 100):
							objectTab[1].node.position.controller.setWeight 2 100
							objectTab[1].node.rotation.controller.setWeight 2 100
						(objectTab[1].node.position.controller.getWeight 3 == 100):
							objectTab[1].node.position.controller.setWeight 3 100
							objectTab[1].node.rotation.controller.setWeight 3 100
					sliderTime += 1
					case of
						(item == 1):
						(item == 2):
						(item == 3):
						(item == 4):
				enableSceneRedraw()
	addModifier childBox (EmptyModifier name:"Parent Switching")
	custAttributes.add childBox.modifiers[1] ca
	append childBox.modifiers[1].myParentTest.objectTab (nodeTransformMonitor node:parentPt forwardTransformChangeMsgs:false)
	append childBox.modifiers[1].myParentTest.objectTab (nodeTransformMonitor node:childBox forwardTransformChangeMsgs:false)
I uploaded a brief video to Vimeo showing how to work with it: https://vimeo.com/89361411
Animatable Pivot
	delete objects
	myBox = Box name:"myBox"
	myAnimHelper = Point name:"animHelper" centerAxis:false axisTripod:false cross:false box:true
	myMoveHelper = Point name:"moveHelper" centerAxis:false axisTripod:false cross:true box:false
	myObjs = #(myBox, myAnimHelper, myMoveHelper)
	myAnimHelper.parent = myBox
	myMoveHelper.parent = myBox
	myBox.transform.controller = CATHDPivotTrans()
	myBox.transform.controller[#PRS].position.controller = Position_List()
	myAnimHelper.position.controller = Bezier_Position()
	myBox.transform.controller.pivot.controller = myAnimHelper.position.controller
	paramWire.connect myAnimHelper.transform.controller[#Position] myBox.transform.controller[#PRS][#Position][#Position_XYZ] "Position"
	myBox.transform.controller[#PRS][#Position][#Available].controller = Position_XYZ()
	myBox.transform.controller[#PRS][#Position].active = 2
	ca = attributes animPivotCA
		parameters animPivotP rollout:animPivotR
			nodeArray type:#maxObjectTab tabSize:0 tabSizeVariable:true
		rollout animPivotR "Pivot Controls"
			button hideMove "Show/Hide Mover" align:#center width:130
			button snapMove "Snap Pivot to Move" align:#center width:130
			on hideMove pressed do
				if nodeArray[2].node.isHidden == true then
					nodeArray[2].node.isHidden = false
					nodeArray[3].node.isHidden = false
				else
					nodeArray[2].node.isHidden = true
					nodeArray[3].node.isHidden = true
			on snapMove pressed do
				myLocalPos = nodeArray[3].node.position.controller.value
				myPos = nodeArray[3].node.position
				myWorldPos = nodeArray[2].node.position
				nodeArray[2].node.position.controller.value = myLocalPos
				nodeArray[1].node.position= myPos
	addModifier myBox (EmptyModifier())
	custAttributes.add myBox.modifiers[1] ca
	for a in myObjs do
		append myBox.modifiers[1].animPivotCA.nodeArray (nodeTransformMonitor node:a forwardTransformChangeMsgs:false)
The animatable pivot script is a strange one, it works perfectly well without Auto Key enabled but messes up with it on, but I thought it might be a good starting point for someone to do further development (I know Felix Joleanes has an animatable pivot plug-in but, hey, it’s fun trying to write your own stuff). It’s based on Jason Schleifer’s approach in Maya, use the cross helper to get the location of where you want the pivot to be and then “Snap Pivot to Move” button to actually reposition the pivot
Hopefully they’ll be of use to someone.
-Harry
